Hello,
I have problem with my new PIC 16f877 controller. I was searching answer to the problem with google and found this site with very friendly people on it so i decided to ask help here even the problem is not picbasic relative. However im going to use picbasic after this problem is fixed.
Backround:
Im totally new to microcontrollers and there migth be something obvious that i have missed, so easy suggestions are important too. I have bougth PIC 16f877 controller and made circuit for it. As programmer i use a LVP circuit that seems to work as i can tell: writing a program to it result no errors and when reading the controllers memory, i can see changes in the hex file downloaded.
Problem:
As the programming seems to work, next thing i have tried to do is to see if there is some life when i turn power on. For this, i have programmed a assembler program to put a voltage to a pin to measure it with voltage meter or to see connected LED to ligth up.
(MPLAB)
LIST p=16f877
INCLUDE "p16f877.inc"
__CONFIG _PWRTE_ON & _HS_OSC & _WDT_OFF & _BODEN_OFF
ORG 0x00
goto Main
ORG 0x04
goto Main
Main
BANKSEL TRISB
bcf TRISB,5 ; i also have tried clrf TRISB without success
BANKSEL PORTB
bsf PORTB,5
Loop NOP
goto Loop
No voltage appears on the pin (tried some other pins too). Here is the circuit: http://kuvaton.com/k/Q8m.jpg edit: from RB3 there goes a wire to ground
I have tested the circuit also with computer powersupply +5V and ground to points A and B in the link above with no success. When tried that, i disconnected stabilization capacitors and the ground pin in the regulator to avoid them to interference.
I saw some circuits in the web where ceramic capacitors where used in some parts of the circuit. In my circuit all the capacitors are electrolyte capacitors, does this make a difference? Unfortunately i dont have any ceramic versions to test.
I will be thankful for any suggestion.
