		serin with pic18f2525
		Hi everyone hope you can help me.
 I have been updating a pic 16f876A program to run on a 18F2525 @8 MHz
 header details are
 'pic18f2525
 DEFINE OSC 8
 OSCCON = %11111111
 DEFINE LOADER_USED 1 ' Comment out if not using boot-loader
 INCLUDE "modedefs.bas"
 INTCON2.7 = 0              'enable weak pull-ups on PORTB
 but when I run it crashes after about 1 minute every time except when I remove this line
 SerIn2 portC.7,16572,600, Loop,[wait("FMS"),dec3 B0]
 It seems simple enough but I am just stuck.
 the transmit  bit works fine
 SEROUT2 PortC.6,16572,["LOADX",#volt1,"BATY",#TXBat]
 what could it be ?
 any suggestions
 many thanks again
 John
		More Information
		Hi again I hope someone will look at this post and help me with my problem. I have reduced the code to a minimum but it still runs for about a minute then crashes.
 Any help most wecome
 thanks again John
 'pic18f2525
 DEFINE OSC 8
 OSCCON = %11111111
 TXBAT       var word
 Volt1       var word
 SIGN        VAR BYTE
 B0          VAR BYTE
 B0 =100
 SIGN = 1
 VOLT1 = 2222
 TXBAT = 90
 ' MAIN lOOP
 Loop:
 GOSUB Transmit
 GOSUB SerialInput
 GOTO Loop
 ' Get Serial Input to serial port 9600 baud inverted
 Serialinput:
 SerIn2 portC.7,16468,1000,loop,[wait ("FMS"),dec3 B0]
 ' Get Load Value and output to serial port 9600 baud inverted WITH - SIGN
 Transmit :
 SEROUT2 PortC.6,16468,["SIGN",#SIGN,"LOADX",#volt1,"BATY",#TXBat,"SIGN",#  SIGN,"LOADX",#volt1,"BATY",#TXBat,"SIGN",#SIGN,"LO  ADX",#volt1,"BATY",#TXBat]
		Still no Joy
		Hi there,
 I have tried the code on a 18f2220 but still the same problem. I tried using DEBUGIN but still the same. Is it to do with the settings of the Hardware UART?, I am not actually sending anything to the pic only sending data at present, but it still fails if I include the serin2 line.
 anyone out there with any suggestions . I would be eternally grateful
 cheers John
		I am just making a wild guess, maybe PORTC.7 should be set LATC.7.
 http://www.picbasic.co.uk/forum/show...57&postcount=9
 If I understand this right, LATC will set the pin digital and PORTC is schmitt trigger.
		18F2525 issues
		thanks  Dave, I will give it a try, under pressure at the moment but I will let you know if it worked.
 many thanks again
 john
