Hi all,
I'm working on a module to receive data from a logger and display the data on a LCD.
From my previous post i came up with a solution to receive the data from the logger into an eeprom. I'm using the code:
All works fine except when the logger stops sending data and i have to go back to the main menu to display the received data.Code:DEBUGIN [DEC VALUE]
I thought of using interrupts but came across some issues:
First let me show you the test code:
Code:'PIC 16F88 - module for logger
CMCON=7 'comparators off
CVRCON=0 'Vref Off
CCP1CON=0
T1CON=0
TRISA=%00101010
TRISB=%00000011
INTCON.1 = 0 'Clear RB0/INT External Interrupt Flag bit & re-enable interrupts
'DEFINEs
@ DEVICE INTRC_OSC
@ DEVICE MCLR_OFF
@ DEVICE PROTECT_OFF
DEFINE OSC 8
@ DEVICE CPD_OFF
@ DEVICE LVP_OFF
@ DEVICE BOD_OFF
@ DEVICE PWRT_OFF
@ DEVICE WDT_OFF
ADCON1=%00000000
ADCON0=%00000000
ANSEL=%00000000
' DEFINE LCD pins
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTA
DEFINE LCD_RSBIT 6
DEFINE LCD_EREG PORTA
DEFINE LCD_EBIT 7
DEFINE LCD_BITS 4
DEFINE LCD_COMMANDUS 2000
Include "modedefs.bas" 'Include serial modes
DEFINE DEBUG_REG PORTA
DEFINE DEBUG_BIT 0
DEFINE DEBUG_BAUD 9600
DEFINE DEBUG_MODE 1
DEFINE DEBUGIN_REG PORTA
DEFINE DEBUGIN_BIT 1
DEFINE DEBUGIN_BAUD 9600
DEFINE DEBUGIN_MODE 1
'PINS
out var PORTA.0 'also used for ICSP
in var PORTA.1 'also used for ICSP
LED var porta.2 'change led for a button
A3 var porta.3 'NC
a4 var porta.4 'check PCB
pgm var porta.5 'reserved for ICSP
RsBit var porta.6 'RS-Bit for LCD
EBit var porta.7 'E-Bit for LCD
BUT1 var portb.0 'interrupt button
BUT2 var portb.1 'button2
SCL var PORTB.2 ' eeprom SCL pin
SDA var PORTB.3 ' eeprom SDA pin
lcd4 var portb.4 'Data pin for LCD
lcd5 var portb.5 'Data pin for LCD
lcd6 var portb.6 'Data pin for LCD
lcd7 var portb.7 'Data pin for LCD
'variables
value var WORD 'value received
INIT:
high out
debug $0D, $0A,13,10
PAUSE 50
debug "Module initialization...",13,10
lcdout $fe,1,"initialization"
STP:
lcdout $fe,1,"1-READ - 2-WRITE"
debug "1-READ - 2-WRITE",13,10
IF BUT1=1 then
WHILE BUT1=1
WEND
INTCON=$90
On Interrupt Goto stall
GOTO rd
IF BUT2=1 then
WHILE BUT2=1
WEND
GOTO wt
GOTO STP
rd:
lcdout $fe,1,"choosen 1-READ"
DEBUGIN [DEC VALUE]
lcdout $fe,1,"1-READ...cont"
pause 1500
INTCON=$80
goto stp
wt:
lcdout $fe,1,"choosen 2-WRITE"
pause 1500
goto stp
disable
stall:
lcdout $fe,1,"pressed interupt"
INTCON.1 = 0
pause 1500
resume
After checking the manual, it states that it should have the RESUME line. So far so good, but i dont what it to resume but instead go to one label and then go where ever i want. So i did this:
The result was that the program after the interrupt just stayed looped inside the labeled stall.Is it a must to resume ???Code:stall:
INTCON.1 = 0
pause 1500
'resume
goto stp
One other thing is that following the manual's example of placing
Does not work because pressing the button it goes directly to the labeled stall ( not passing through the labeled rd ).Code:On Interrupt Goto stall
INTCON=$90 'start interrupts
I changed it with
And this way works as expected. Is the manual wrong ?Code:INTCON=$90 'start interrupts
One last thing i noticed is that when a PAUSE command is being executed the interrupt needs to wait until it jumps to it's label.
This is also true with the DEBUGIN [DEC VALUE] command. Meaning that not receiving any data it will hang here. The interrupt will not cancel this line.
Being true how can I cancel the input of data when it's finish ??
Sorry for the long post
