Debug vs SerOut Commands
A couple of questions regarding these two commands.
1) is there any inherent advantage of one over the other?
2)Relative to code execution, when a SerOut command is executed, say
SerOut 3,N2400,["This is a test"]
does execution pause for the 58ms that it takes to send out the text?
Any insight would be helpful.
Thanks.....chris
DEBUG and SEROUT will work the same.
DEBUG take less of your code space but you are a really little bit limited for the functions. Have a look in PBP manual to see differences.
Serial is serial, in most case, DEBUG may be use instead of SEROUT.
regards
