Hi all!
On which I/O pins (16F688) can I expect to find the PBP default connections for an LCD (44780)?
Asking since this device doesn’t have any PORT B.
Thanks.
Hi all!
Thanks.
Hi skimask,
No, I would probably manage to set the pins straight but it is against my principals to fiddle with things for no reason (call it lazy if you want!). :-) That’s why I was wondering where to find them on this device as default.
This “project” is at an early stage (on paper) so I am just trying to figure out which pins are available after hooking up an LCD (on the default pins). :-)
Well, that's one reason to learn why everything works the way everything works...
'cause if you did...you may also find out that on a parallel LCD, you don't necessarily need the R/W pin connected, just tie it low.
There ya go! Saved you 1 pin...
You can actually figure it out for yourself.
Make a program that accesses the LCD, compile it, assemble it, set up MCS to output a .LST file (before compiling and assembling), then search that .LST file for the LCDOUT command. If you look close enough, you should be able to see references in that .LST file as to where the command is going to send data/control signals.
I did lookinto the .LST file but there was a LOT of LCDOUT’s! So I decided (easy way out) to assign pins for the LCD myself and it works perfectly.
Thanks skimask! (and don’t say “I told you so”!) :-)
