Maximum HPWM freq. 12F683
I need to know the maximum HPWM frequency I can run on a 12F683 using the internal 8 MHz osc. I know that the manual says "32 point whatever" is the max for HPWM on any chip, but reading some posts with mister-e's pic calc it looks as though it can do 38 kHz for IR modulation.
I'll be doing some IR modulating as well, but I have some 56 kHz detectors that i'd like to use,
which would require that i output a 56 kHz signal on the HPWM output while i read the detector on another port. I really need this to be a one chip solution, insted of having a 56 kHz osc using logic chips AND having a pic to read the detector....
so to recap.. ONE pic12F683 driving a IR led on the HPWM at 56 kHz while using the same PIC to read the IR detector on a different port. can this be done?
Also.. I cannot install the pic calc on this computer, I don't have admin rights.....
