hi guys!
im using SPI between the two pics. here is my program for SPI master
Code:'****************************************************************
'* Name : UNTITLED.BAS *
'* Notice : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 7/5/2008 *
'* Version : 1.0 *
'* Notes : *
Include "Modedefs.Bas"
DEFINE HSER_RCSTA 90h
DEFINE HSER_TXSTA 24h
DEFINE HSER_BAUD 9600
DEFINE HSER_SPBRG 25
define OSC 4
' Set LCD Data port
DEFINE LCD_DREG PORTD
' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_DBIT 0
' Set LCD Register Select port
DEFINE LCD_RSREG PORTC
' Set LCD Register Select bit
DEFINE LCD_RSBIT 0
' Set LCD Enable port
DEFINE LCD_EREG PORTC
' Set LCD Enable bit
DEFINE LCD_EBIT 1
' Set LCD bus size (4 or 8 bits)
DEFINE LCD_BITS 8
' Set number of lines on LCD
DEFINE LCD_LINES 2
' Set command delay time in us
DEFINE LCD_COMMANDUS 2000
' Set data delay time in us
DEFINE LCD_DATAUS 50
SSPEN VAR SSPCON1.5 'SSP Enable bit
CKP VAR SSPCON1.4 'Clock Polarity Select
SMP VAR SSPSTAT.7 'Data input sample phase
CKE VAR SSPSTAT.6 'Clock Edge Select bit
SSPIF VAR PIR1.3 'SPI interrupt flag
i VAR BYTE
j var byte
as var byte[5]
com VAR byte[2]
sen var byte[6]
teds1 var byte[10]
teds2 var byte[10]
teds3 var byte[10]
op1 var byte
teds_out var byte[25]
sen0 var byte[10]
sen_all var byte[20]
a var byte[10]
TRISC = %10010000 'set PORTC I/O
SSPEN = 1 'enable SPI pins
CKP = 0 'clock idle low
CKE = 0 'transmit on idle to active transition
SSPIF = 0 'clear buffer full status
SMP = 0 'sample in middle of data
SSPCON1.0 = 0
SSPCON1.1 = 0
SSPCON1.2 = 0
SSPCON1.3 = 0
j=0
hserout["initialized....",13,10]
hserin [wait("x"),str com\2]
hserout["you entered",str com\3,13,10]
goto loop
loop:
if j>10 then main
high portB.0
pause 25
low portB.0
pause 25
GoSub getdata 'initiate conversion and receive data
LCDOut $fe, 1, STR a\5, DEC a[5] 'display received string
Pause 100
hserout [dec a[4]," ",dec a[5]," ",dec a[6],13,10]
j=j+1
goto loop 'do it forever
getdata:
SSPBUF = "?" 'send ? to start conversion
GoSub letclear 'wait for buffer to clear
IF SSPBUF<>"!" Then getdata 'wait for reply (!)
For i = 0 to 5 'loop for 6 characters
SSPBUF = 0 'write to SSPBUF to start clock
GoSub letclear 'wait for receipt
a[i] = SSPBUF 'store received character in array
Next i 'get next character
letclear:
IF SSPIF = 0 Then letclear 'wait for SPI interupt flag
PauseUs 25 '25uS fudge factor
SSPIF = 0 'reset flag
and here is my SPI slave code
'* Version : 1.0 *
'* Notes : *
define osc 4
DEFINE ADC_BITS 8
DEFINE ADC_CLOCK 8
DEFINE ADC_SAMPLEUS 50
' Set LCD Data port
DEFINE LCD_DBIT 0
DEFINE LCD_RSBIT 0
DEFINE LCD_EBIT 1
DEFINE LCD_BITS 8
DEFINE LCD_LINES 2
out VAR BYTE[8]
out2 var byte[8]
out3 var byte[8]
teds var byte[20]
teds_out var byte[11]
sen0 var byte[10]
i var byte
j var byte
op1 var byte
SSPEN VAR SSPCON1.5
CKP VAR SSPCON1.4
SMP VAR SSPSTAT.7
CKE VAR SSPSTAT.6
SSPIF VAR PIR1.3
SCL Var PortB.6
SDA Var PortB.7
TRISC = %11011111 'set PORTC I/O
SSPCON1 = %00000101 'configure SPI slave, no SS
CKP = 0
CKE = 0
SSPIF = 0
SMP = 0
ADCON1 = $00
INTCON3.3=1
INTCON2.7=0
INTCON2.5=0
INTCON3.0=0
INTCON3.6=1
' PicBasic Pro SPI slave program (see SPImast.bas for connections)
' Allocate RAM
dataout VAR BYTE[8] 'Data out array
'ADCON1 = $00 'PORTA.0 analog, rest PORTA and PORTE pins to digital
dataout[0] = "A" 'Preset output data to "ADC= "
dataout[1] = "D"
dataout[2] = "C"
dataout[3] = "="
dataout[4] = " "
find:
if INTCON3.0=1 THEN loop
HIGH PORTC.1
PAUSE 100
LOW PORTC.1
PAUSE 100
goto find
loop:
INTCON3.3=0
INTCON3.0=0
SSPEN = 0 'disable/enable SSP to reset port
SSPEN = 1
GoSub letclear 'wait for byte received
IF (SSPBUF <> "?") Then loop 'wait for ? to start conversion
ADCIN 1, dataout[5] 'Read ADC channel 0, store in 6th position of string
pause 50
GoSub senddata 'send "!" and string of data
INTCON3.3=1
pause 10
GoTo loop 'do it forever
senddata:
GoSub letclear 'wait until buffer ready
SSPBUF = "!" 'send reply
For i = 0 to 5 'loop for 6 array locations
SSPBUF = dataout[i] 'send array variable
Next i 'next location
letclear:
IF SSPIF = 0 Then letclear 'wait for interrupt flag
The problem is coming with SPI master. It is connected with serial port to Labview. when the circuit is switched on it displayes
Initialized...
(then it ask to enter two string data)
then it displays
You pressed (string data that we entered)
and then it displays sensor reading 11 times.
I have put the condition that when j>10 then goto main and ask for the string data again.
But this doesnt work. It displays sensor data correctly 11 times, and then initialized is displayed and then it halts, i enter the values but nothing happens. Please tell me what is the problem with this,
I shall be thankful to u for this
