if i have 2 arrays arrayone[7] and arraytwo[7]
can I copy them all together:
arraytwo = arrayone
or do i have to do each part seperatly?
arraytwo = arrayone
never test it but i really think you must copy item by item in a simple loop.
for a=0 to 6
arraytwo[a]=arrayone[a]
next
regards
thanks
can i do any manipulation with a whole array?
if arrayone <> 0 then goto dealwithit
i don't think we can do anything with an whole array. only with separate items... loop again
regards
this might be a daily occurance... i think i might need my own forum for my questions.... scorpion's stupid subject of the day.
anyways
is it possible to do floating point math ie. #### / 10.24
or should i shift the #s over divide and then move back?
Hello Scorpion
S>>is it possible to do floating point math ie. #### / 10.24
or should i shift the #s over divide and then move back?<<
yes, you can do Floats.
Dwayne
Hi Scorpion,
You can do floats, it's described on Melabs page. However, there's a different way, calculations with fractions. This is done with the "*/" or "**" operators. Tracey Allen has done a good job of describing theese(and a lot more) on his site http://www.emesys.com/BS2math1.htm .
The "*/" operator does an "invisible" division by 256.
The "**" operator does an "invisible" division by 65536.
Lets say you want to calculate Y=X/10.24 ......
X VAR WORD
Y VAR WORD
Y = X */ 25
This would be the same as doing X*25/256 on your calculator. 25/256 is equal to 1/10.24.
/Ingvar
