Schottky for surge & polarity protection?
This is a basic electronics question, but everything I find on google goes into tons of detail of how exactly a schottky is constructed and it's characteristics, but I can't find straight up practical application examples for it.
I've got 2 things I'm trying to solve, and I think a schotty may be a solution for them both; but I'm not sure how exactly it would be implemented...
1) Surge / spike protection. I've got a radio receiver that will operate in an area that experiences a high current EMP spike as the attached hardware activates. The spike induces between 2 and 15 volts in an open wire on a scope. I'm a bit concerned that the EMP could be coupled into the antenna and result in a voltage spike into the radio receiver and burn it out. We've tested it to the extreme (lots and lots of test spikes) and it keeps working fine, but I'd feel much better knowing I've done the "right" thing in preventing this. I think a schottky could be used to direct a high voltage spike (maybe anything more than 1 to 2 volts) directly into the ground plane. I also think a zener could be used? Whatever it is, it would have to be really fast acting as the spike is really short - maybe 100nS.
2) Polarity protection. Assume my circuit is all complete with a voltage regulator, pic, and varous components. It's powered from a single battery cell, and I want to add reverse polartiy proection (if the user puts the batt in backward). I put a batt in backward and it seems fine but again, I'd like to add some intentional protection for this.
Specific help or links to example schematics much appreciated. If I could just see how these things are used I think I could figure out how to use them for my application.
Thanks!
Anti-parralel diodes shottky diodes should do it.
During blizzards in the Antarctic we used to get 25-35 mm sparks off unterminated antennae caused by static buildup from the passing ice crystals. That would rip the front ends right out of the receivers until we tried a pair of anti-parralel shottkys across the input. The earth braid to ground had to be beefed up to reduce noise.
HTH
BrianT
Understand the uses of TVS and Schottky Devices
Transorbs (like SMBJ) and other TVS (transient volt suppressors) are great for transients. In fact, for lightning protection and such TVS devices are used widely (these are what you find in your surge protection power strips). Schottky diodes would never whidstand lightning transients (and live to see another day).
But schottly diodes have very little capacitance, transorbs generally have a great deal of capacitance. So if you hang a transorb directly across the antenna input, you may as well not worry about reception / transmission (since you will have none).
In your case, a schottky diode in an anti-parallel configuration (as was suggested) maybe all you need. Should you require to add the TVS (there are some very good bidrectional ones - look up AVX's TVS) to the antenna line, you will want to have an RF choke (RF inductor) in series with the TVS. The choke connects between the antenna line and TVS, and the TVS betweeb the choke and power rail (GND most likely). Lookup the following appnotes, they have very good info:
What is a Silicon TVS and How Does it Work?
Selecting the Optimum Transient Voltage Suppressor
