Hi, im back to my disco lights again now i have a little money. Im going to use RS485 now as recommended by people on here. Ive had a look on google and it appears there is a MAX485 chip.
Ive read on the net that there is a need for a 3rd wire to link the grounds together and a shielded wire. The wires im using are XLR Mic/DMX wires. The longest is 20 meters and works fine for DMX. Im not sure if these wires are shielded or even twisted pair though. I would have thought not since there are 3 wires inside. Ive never noticed any interference while using them with DMX lights so will they work with RS485?
Does 3 wires mean i can only have a 1 way signal? The diagram at the bottom of page 7 in that datasheet almost makes it look like i can have a 2 way signal but i cant see how that would work.
How do i connect this chip to a PIC chip? Is it as simple as putting wires between the 2 or do i need resistors etc? Looking at that diagram it appears i dont need any external capacitors like i do with MAX232. Is that right?
