Looping Variable Assignments
I am building an application that reads an analog signal from one of the adc pins and then saves it to a progressively different variable. I want this action to be looped so I can do it 50 or so times before coming out of the loop. So my question is is their any way of incrementally changing the ram byte address each time the loop comes around or do I have to spell out each variable address (b0,b2,b3…) in my code. I know this is posable if I do this for sending the data to the eeprom but I don't want to slow down the process. Also is it true that the picbasic compiler can only access 96 bytes of ram? I want to take advantage of the PIC16F688 256B of ram. Thanks in advance.
-Jacob B.
