I am using a 16f688 and I use HSEROUT with no problems. I now need to send some data back to the 16f688. How do I format the HSERIN command if I don't know how much data is coming?
Bob Hiller
Lifts for the Disabled LLC
Bob Hiller
I see no reference to filling an array and waiting for termination characters in the PBP manual. Do you have a sample?
Bob Hiller
I think he meant ...
See HSERIN in the PBP manual. Look at the STR modifier.
<br>
Being a beginner myself I have the same problem with getting simple commands and mondifiers to function. I'm looking in the PBP manual at the STR Modifier and they just don't give any examples on how to use it. I'm also interested in the use of this function as I would like to be able to send commands to the PIC and dinamicly update it.
MyVars VAR BYTE(8)
HSERIN 500,NoData,[STR MyVars\8\"~"]
NoData:
do something else
This will wait 500mS before jumping to NoData. It will receive a string of up to 8 characters
in byte array MyVars, or exit on receipt of the "~" character.
From a PC I send 123:CRLF as 495051581310
When I try:
MyVars VAR BYTE(8)
HSERIN 500,NoData,[STR MyVars\6\":"]
NoData:
HSEROUT ["Timeout",$0d,$0a]
Goto main
It always goes to NoData. I never get anything into MyVars.
If I use HSERIN 500,NoData,[STR MyVars\1\":"] I get random data. It is different each time I send the data.
What am I missing?
Bob Hiller
Have you tried increasing the timeout period?
P.S. How do you know what you're receiving? Your example doesn't show how you're
checking what's received!
Don't send 123:CRLF as 495051581310....send it as 123:<CR> with line feeds turned on at the PC.
HSERIN doesn't need to use raw hex codes for the data (i.e. sending 10 for a line feed, etc).
Are you using the internal oscillator on the PIC?
The internal oscillator isn't always accurate. Could cause your baud rate to be off by just enough to confuse everything.
Are you using a MAX232 type device between the PIC and the PC?
The hardware UART uses 'TTL-RS232', commonly called 'Normal' in PBP circles. Try using SERIN2/SEROUT2 and using an inverted mode if you don't have a MAX232.
Are you sure the PIC is configured correctly for the desired baud rate?
Can get a bit confusing with all of the options a PIC has. Double check them...
Are you sure the config registers/any other registers are set up correctly?
Internal vs. External crystals...and so on and so on...
I am using MAX32 between the PC and PIC.
HSEROUT works every time no matter what I send. Thank makes me assume that the BAUD issue is OK.
Here is how I check what I am receiving:
HSEROUT ["B1 ", MyVars(0), $0d,$0a]
HSEROUT ["B2 ", MyVars(1), $0d,$0a]
HSEROUT ["B3 ", MyVars(2), $0d,$0a]
HSEROUT ["B4 ", MyVars(3), $0d,$0a]
HSEROUT ["B5 ", MyVars(4), $0d,$0a]
etc..
Ok, just checking, didn't have that info before.
Like I said before, don't send the raw hex data back and forth, just send the characters themselves.
At the PC, type in a few characters (no hex codes, nothing crazy, just a few alpha or number characters), followed by the : character.Code:MyVars VAR BYTE[8] : temp var byte
Main: HSERIN 5000,NoData,[STR MyVars\6\":"]
HSEROUT ["Received:", STR myvars\8",13,10] : goto main
NoData: HSEROUT ["Timeout",$0d,$0a]
for temp = 0 to 8 : myvars[temp]=0 : next temp 'clean out myvars
Goto main
The code above should wait for 5 seconds to 1)get no data, 2) get 6 bytes of data, or 3)will kick out and send back the data you just sent if you sent a : before you sent a total of 6 bytes.
Hi Skimask
Counter 0 to 7, perhaps? And possibly no quote marks in third line after 8?
Adrian
Hi Skimask
Thanks but there is something I'm not understanding. I've tried your programme and it works fine until the first timeout then it won't 'goto main' and loop through again. Should it? If I change the counter to FOR temp = 0 to 7 then the programme loops round endlessly. What am I not understanding or what am I doing wrong? Please help - going mad here!!
Adrian
Might get a couple of hints from this:
http://www.picbasic.co.uk/forum/show...ht=hserin+idle
If not there, then try a search on serial and idle and see what happens.
I usually refer back to this sample program if I forget how to use a modifier;
http://www.melabs.com/resources/samples.htm
and load the sample program ser2mod.bas
Bob
Thanks for that Bob. The bit I was confused about is Skimask's statement "MyVars var Byte[8] sets aside 9 bytes, index 0 (zero) is also valid"
I thought I understood that MyVars VAR BYTE[8] had 8 elements numbered 0 to 7 (Page 26 PBP new manual). If that were the case then the 'clearance' counter ought surely to be 0 to 7 not 0 to 8, which would be invalid.
Adrian
Thank you for that, Skimask. I really appreciate you coming back and putting this one to bed once and for all. I guess that Counter 0 to 7 clears the temp array and 0 to 8 hangs up due to the extra 'rogue' index.
I really do appreciate your input and have learned some more about this interesting and all absorbing science
Regards & thanks
Adrian
