Howdeedoo all...
I'm stuck here. I'm trying to get an Optrex DMC20481 (4 x 20 display) to work with a 16f877 and I'm getting nuttin! It doesn't even flicker. I've checked and re-check the wiring. It all looks good. I disconnected the LCD and wrote a simple program to pulse the connector pins... the data seems to be getting through fine telling me it's not likely a circuit board problem.
This is a new circuit board with a 3-8 decoder enabling one of several paths for portd through 74HC373 chips. The decoder inputs are connected to porte of the 877.
I am using Microcode Studio with the latest version of PicBasic Pro.
I've probably dones something screwie. Any input here would be most appreciated.
Thank you,
Ross
DEFINE LOADER_USED 1
DEFINE osc 20
ADCON1 = 7 'set porta to digital
TRISA = 0 'set porta to output
TRISD = 0 'set portd to output
TRISE = 0 'set porte to output
Define LCD_DREG PORTD 'I/O port where LCD is connected
DEFINE LCD_DBIT 4
DEFine LCD_RSREG PORTD 'Port where RS pin located
define LCD_RSBIT 2 'Register select pin
Define LCD_EREG PORTD 'Port where Enable pin located
DEFINE LCD_EBIT 3 'Enable pin
DEFINE LCD_BITS 4 '4-Bit data bus
define LCD_LINES 4 'Number of LCD Character Display lines
'Porte is connected to 74HC138 3-to-8 line decoder which directs portd to one
'of several devices by enabling the correct 74hc373.
porte = 5 'Enable 74hc373 connecting Portd output to LCD
pause 2000 'Two seconds for display power-up (should be enough)
lcdout $fe,1 'Clear the LCD screen
pause 100 'Don't think I need this pause
porta.0 = 1 'initialize porta.0 (where LED is connected)
gosub flash_led
lcdout "Success"
lcdout $fe,1
'Led is connected to porta.0. As the main program loops, it flashes the LED as
'visual feedback that the program is at least trying to work. *razzberry*
flash_led:
pulsout porta.0,50
