rick hardy
Is there anyone who has built the PIC16F84-controlled 8 servo motor biped in Jon Iovine's PIC book ?
I have.
This is the latest problem I ran into:
The biped starts off by initializing its stance (knees bent forward).
When it goes into its first movement, both ankles tilt to the left and the robot falls over and then nothing occurs, as far as any other individual servo movements.
Anyone else run into this problem ?
I just got to thinking about my problem and had this thought:
Jon Iovine recommends putting a GOTO HOLD statement after each movement, so you can see the movement and tweak the positioning of the servos if need be. I did that after the first movement, but then got greedy, removed the GOTO HOLD statement after the 1st movement, reprogrammed the chip and tried it again; the same thing happened.
<font color = red>Is it possible that the GOTO HOLD statement I removed after the 1st movement is still "burned" into the chip ?</font color>
I thought that all the code is erased before it is "burned" again ? or is there a setting I need to check ?
