Problem driving a laser pointer
As a beginner, I am trying to drive a laser pointer from a PIC16F84 using this simple program:
loop: High 0 'Turn on LED connected to RB0
Pause 1000 'Delay for 1 second
Low 0 'Turn off LED connected to RB0
Pause 500 'Delay for 0,5 seconds
GoTo loop 'Go back to loop and blink LED forever
For sure it flashes but it looses much brightness.
I tried to drive the laser pointer from a TIL111
using the following circuit but it still looses much brightness.
http://www3.sympatico.ca/louiscimon/...9v%2016f84.pdf
I suppose that "High" is in fact an oscillation that is not a continuously "on".
I have the same difficulty trying to drive a piezzo buzzer
(Velleman SV10) : it looses much loudness in the process, even driving it from 18 v
with the TIL111.
I would like to understand and find a solution.
Thank you very much
Louis Cimon
Québec, QC
Canada
Hi Jumper,
Thank you for your input.
I changed the resistor for a 470 ohm.
I am reading 4,92 v between rb0 and ground
and 4,92 v between TIL111 pin 1 and ground
I am reading 8,35v between TIL 5 and battery and the battery produces 8,35 v.
I tested my piezzo on two 9v batteries in series and the sound output is greatly reduced when I drive it with the TIL111 compared to driving it directly with the batteries. The voltage readings of the batteries and the TIL11 output are the same.
Solution?
