		Pic16f690 Hserin
		HI
 I'm experiencing a problem with HSERIN command using Pic16F690 a sample PBP code, does not receive any character, but the sending of characters it work fine ( Hello World ).
 If I use PIC16F877 OR PIC16F627A the code works fine, any help?
 Im use hyper terminal on PC side.
 ' PicBasic Pro program to send and receive from
 ' the hardware serial port
 DEFINE HSER_BAUD 2400   ' Select the baud rate
 char var byte		    ' Storage for serial character
 start:
 Hserout ["Hello World", 13, 10]	' Send text followed by carriage return and linefeed
 loop:
 Hserin 10000, start, [char]	' Get a char from serial port
 Hserout [char]		        ' Send char out serial port
 Goto loop		            ' Do it all over again
		Add ANSELH=0 to the top section of your code. P.S. you can get answers without multiple posts on the same subject..;o}
