		Pic16f690 Hserin
		HI
 I'm experiencing a problem with HSERIN command using Pic16F690 a sample PBP code, does not receive any character, but the sending of characters it work fine ( Hello World ).
 If I use PIC16F877 OR PIC16F627A the code works fine, any help?
 ' PicBasic Pro program to send and receive from
 ' the hardware serial port
 DEFINE HSER_BAUD 2400   ' Select the baud rate
 char var byte		    ' Storage for serial character
 start:
 Hserout ["Hello World", 13, 10]	' Send text followed by carriage return and linefeed
 loop:
 Hserin 10000, start, [char]	' Get a char from serial port
 Hserout [char]		        ' Send char out serial port
 Goto loop		            ' Do it all over again
		Which version of PBP are you compiling with?
		Pic16f690 Hserin
		Hello  Skymask, Is Pbpro 2.46
		Pic16f690 Hserin
		Hello Skimask, Pbp Version Is 2.46 Thanks In Advance For Your Help.
		Pic16f690 Hserin
		Thanks Bruce Yes I Have Already Done, Sorry Everybody But English Is Not Mi Natal Language, The Curious Is With Pic 16f877 And Pic16f627a Work Without Any Changes, Of Course I Select The Apropiate Microcontroller In My Programmer And Microcode Studio.
		Datasheet page 8.  RX pin is also AN11, you should disable it.
 Datasheet page 120, table 9-2
 ANSELH=0
		ANSELH=0 should cure that.
		Pic16f690 Hserin
		thanks guys, ANSELH=0 fix the code, now is working. sorry but I AM new to micro programming.
		;) You're welcome.  We all have to begin somewhere, and one day we all had problem like that.
 In case of doubt, refer to the following thread
 http://www.picbasic.co.uk/forum/showthread.php?t=561
 Post #2 have a nice PDF, i suggest you to keep it handy somewhere on your hard drive.
 Have fun!
