Combination programming
I'm not really sure what to call what I am doing so I'll explain it first.
What I am trying to do is chane an array for a variable based off another variable.
outpVr_1 Var Byte
outpVr_2 Var Byte
fstVar Var Byte
fstVar = 1
sndVar Var Byte
sndVar = 1
if fstVar = 15 Then
fstVar = 1
if fstVar = 0 Then
fstVar = 14
if sndVar = 15 Then
sndVar = 1
if sndVar < 0 Then
sndVar = 14
if portE.0 = 0 then
fstVar = fstVar+1
if portE.1 = 0 then
sndVar = sndVar+1
outpVr_(fstVar) = sndVar
Basically if I have fstVar as 1, I want to incriment outpVar_1 as sndVar. if I have fstVar as 2 then I want to incriment outpVr_2 as sndVar. (basically like I have it at the end of the code) I don't know if it will work like this though and I don't want to have to use 10,000 IF THEN statements to encompass all the possibilities. I did a test of this a while back and I ended up running out of space on my chip (I'm using a very simple example here)
another way to think of it is as a combination dial lock. If you have the first number as 1 you can change the second number, then when you switch the first number to 2, the second number can be something different, but still remember what the second number was for 1. Oh man, this is confusing trying to write, I hope it makes sense.
Please let me know if something like this is possible and how I can get it to work.
