Need help in booting/wakeup pc by lan using PIC16f628
Hi Friends,
I Need help in booting/wake up my PC using lan card(supported by BIOS) using PIC16f628.
I want my pc to wake-up/boot and record some audio (VHF 2M NET). I have witten timmer code by not able to write code for wake up/boot pc. I am using PIC16f628,xtal-4mhz.
Any help for wake up/boot code part is appreciated
thanks for ur time
vu2iia
Look for the WOL connector
If you are using a PCI LAN card then perhaps the LAN card is having a WakeUp On Lan connector already. If your motherboard supports that header then you do not need the PIC otherwise you may use it to boot-up your PC.
Was sometime a VU2SHH .
