serout out of order on 12F675
I´m trying to send data from PIC to BS2 via serout2 but the values are sistematically been altered.
The 12F675 is generating the sequence:
0,1,2,3,4,...,255
And the BS2 is receiving:
128,129,130,131, ... , 157,158,159,128, 129,130,...
I verified and OSCCAL was not erased.
Things got better when i include the line:
Define OSCCAL_1K 1
on the code, but the problem did not dissapear at all.
here are the codes:
12F675 code:
include "bs2defs.bas"
Define OSCCAL_1K 1 ' Set OSCCAL for 1K Device
ANSEL=%00000000
CMCON=%00000111
Trisio = %11111111 ' Set all ports as inputs
Trisio.4 = 0 ' Set port GP4 as output
saida CON 4
i var byte
loop:
for i = 0 to 255
serout2 saida,16780,[i]
next
pause 2000
goto loop
The BS2 code:
' {$STAMP BS2}
' {$PBASIC 2.5}
entr PIN 1
entr_mode CON 16780 'entrada baudmode = 2400/8N1 INV
PAUSE 10
p VAR Byte
Start:
SERIN entr,entr_mode,[p]
DEBUG DEC p," "
GOTO Inicio
Seems to me that is some timing problem. I overnight on this problem without a solution. I must be missing something trivial, but I cant figure out what!
I´ll appreciate any help
Same code worked on a 16F688
Thank you for your comment, I will try your suggestion. Just a note: the code works fine on a 16F688 using the same I/O pin GP4.(with minors modifications: TRISIO replaced by TRISA, ANSEL replaced by ADCON1, CMCON line removed). I didn't try to connect directly to my PC.
