trouble with FLAGs
		hello everyone,  I am trying to do a PWM with a few leds connected to PortB  and have a switch that is connected to one of the pin in PortC.  I want to halt the design when I pressed the switch once.
I have the following in my code.
But I have to press the switch twice for the PWM to stop and twice for the PWM to continue.  but I only want to halt the design when I press the switch once.     I have set the flag  = 1 at the top of my program...  and when the switch is pressed I clear the flag..    any help on this will be greatly appreciated.  Many thanks in advance
srigopal
Flag = 1
For     Duty = 0 to 999
                If Switch = 0 Then
                	Flag = ~Flag
                Endif
                if(Flag = 0)  then
					Duty = Duty - 1
				Endif
				Flag = 1
             		For cycles = 0 to Cycle1
                    	Portb = %00000000
                        Pauseus 999 - Duty
                        Portb = %00000010
                        Pauseus Duty
                    Next cycles
Next Duty
		Try something like this.
IF Switch = 0 Then
    Flag = ~Flag           ' Invert Flag bit
    WHILE Switch = 0   ' Wait for button release
    WEND
 This allows your Switch test routine to control toggling the Flag bit + Switch debounce. Then do whatever you need afterwards based on the Flag bit logic state.
Note: Be sure to use a pull-up on your Switch input, and release the Switch quickly to avoid hanging in the test routine or odd results with a floating input.
		Hi Bruce,  I have tried that.. but when I hold the switch down..  the output of the LEDs is not stable,  it jumps to the NEXT LED   lets say that I want to stop the program when the LED is 35% on .. when I have the switch pressed the LED seems to jump to full brightness .. and when I release it the LED comes back to where I wanted to stop it.   How do I avoid that from happening..
but when I take the  while statement out of the program,  the entire switch works but the flag does not refresh..  then the nest time I would have to press the switch multiple times to make it stop..  it;s very unpredictable.
I even included the a resister between VCC to the Pin and then PIN to GROUND I have the switch.   i dont think that my configuration is wrong  is it?
Hope there is another solution to this
srigopal
		Hi srigopal,
Can you give a little more detail on exactly what it is you're trying to do?
Do you want this switch to "only" stop the duty cycle when pressed, or do you want the switch to provide a "stop" or "go" type action?
		here is what I plan to do...  I want to include a switch that can stop the pwm just by pressing the switch once and letting it go.   and then start it when I press it again and let it go.   this is why the code does not work because the flags are not refreshed.
But I need to do the same with another switch..  which only needs to be pressed to stop the pwm.   so two switch is what I need really.
one that only needs to be pressed once to stop the pwm.... and the other to be pressed whenever you want it to stop and go type of thing.   (one pressed stop the pwm.. the other press continue where it left off )
srigopal
		Hi srigopal,
There are quite a few ways to do this. Here's one. This version just stops your PWM change.
Stop_Switch VAR PORTC.0  ' Whatever pin you prefer
Go_Switch   VAR PORTC.1  ' Whatever pin you prefer
Duty        VAR WORD     ' Duty cycle
LowCycle    VAR WORD     ' Low cycle
HighCycle   VAR WORD     ' High cycle
Period      VAR WORD     ' Frequency period
Cycles      VAR WORD     '
Active      VAR BIT      ' Active/Inactive flag bit
YEP         CON 1        ' PWM will be Active
NOPE        CON 0        ' PWM will not be Active
End_Cycles  CON 500      ' Increase value to slow PWM duty cycle change
Active = YEP             ' PWM defaults to Active
TRISC = %00000011        ' Make em inputs
TRISB = 0                ' All outs
Period = 500             ' Set frequency here. 500 = ~1.983kHz
                         ' 250 = ~3.825kHz, etc,
Duty = 250               ' Set whatever you prefer here to start with
                         ' 250 = ~50% (1/2 of period)
    IF Go_Switch = 0 THEN    ' Go_Switch pressed?
       Active = YEP          ' Yes, toggle flag bit
    IF Stop_Switch = 0 THEN  ' Stop_Switch pressed?
       Active = NOPE         ' Yes. toggle flag bit
    IF Active = YEP THEN
       IF Duty < Period THEN
          Duty = Duty + 1
          Duty = 0           ' Limit Duty from 0 to 100%
    ' Compute high & low cycles of Period
    LowCycle = Period - Duty
    HighCycle = Period - LowCycle
    For Cycles = 0 to End_Cycles
        Portb = %00000000
        Pauseus LowCycle
        Portb = %00000001
        Pauseus HighCycle
    Next Cycles
    GOTO Main
 And if you want to stop PWM altogether, then a slight change in this routine would do it for you.
           Portb = %00000000
           Pauseus LowCycle
           Portb = %00000001
           Pauseus HighCycle
       Next Cycles
 Of course there are many other ways to do this, but this gives you a good idea of at least 1 way.
