HSERIN2 not working on PIC18F97J60 ???
Good morning gurus.
I'm experiencing a problem with HSERIN2 command using Pic18F97J60 (100 pin version)
A simple code like this, does not receive any character, but the sending of characters it work by the use of HSEROUT2:
Include "modedefs.bas" 'Inline compiler's pre-defined constants
define OSC 25 'Set the Crystal Clock speed
DEFINE HSER2_RCSTA 90h 'Set the RX Register for the Serial Port 2
DEFINE HSER2_TXSTA 20h 'Set the Serial Port2 TX enabled
DEFINE HSER2_BAUD 9600 'Set baud rate for Serial Port 2
DEFINE HSER2_SPBRG 40 'Set SPBRG directly ((((1000000*25)/9600)+32)/64)-1
define HSER1_CLROERR 1 'No Error Overflow on Serial Port 1
define HSER2_CLROERR 1 'No Error Overflow on Serial Port 2
ADCON0 = 0 'AD converter module 0 = disabled
ADCON1 = %00001111 'Set all analog pins to digital
ADCON2 = %00000000
CMCON = %00000111 'Comparator = disabled
INTCON = %00111000
INTCON2 = %10000000
INTCON3 = %00000000
RCON.7 = %00000000
T0CON = %00000000 'Timer0 disabled (see page 163)
T1CON = %00000000 'Timer1 disabled (see page 167)
T2CON = %00000000 'Timer2 disabled (see page 173)
T3CON = %00000000 'Timer3 disabled (see page 175)
T4CON = %00000000 'Timer4 disabled (see page 179)
CCP4CON = %00000000 'Capture/Compare/PWM 4 disabled (see page 181)
CCP5CON = %00000000 'Capture/Compare/PWM 5 disabled (see page 181)
CCP1CON = %00000000 'Capture/Compare/PWM 1 disabled (see page 189)
CCP2CON = %00000000 'Capture/Compare/PWM 2 disabled (see page 181)
CCP3CON = %00000000 'Capture/Compare/PWM 3 disabled (see page 181)
EECON2.5 = 0 'Ethernet Module Disabled
SSP1CON1.5 = 0 'Disable SPI 1 and set pins as GPIO
SSP2CON1.5 = 0 'Disable SPI 2 and set pins as GPIO
BAUDCON1 = %00001000 'BRG16=1; See page 304
'BAUDCON2 = %00001000
'Serial Port 1 speed setting:
SPBRGH1 = $02 '9600 bps value for serial port =650=$028A
SPBRG1 = $8A
TXSTA1 = %00100100 'Tx1 enabled,8bit,Async, see page 302
RCSTA1 = %10010000 'Rx1 enabled,8 bit,Async,No frame&overfl.err
'Port D features setting:
PSPCON.4 = 0 'Port D set to be used as GPIO
TRISG.0 = 0
TRISG.1 = 0 'PortG1 = Output (External RS232-TX2)
TRISG.2 = 1 'PortG2 = Input (External RS232-RX2)
TRISG.3 = 0
TRISG.4 = 1
TRISG.5 = 1
TRISG.6 = 1
TRISG.7 = 1
LATG = 0
syncByte var byte
MainLoop:
LED_SysAlive = ~ Led_SysAlive 'Blink a led
HSERIN2 1000, MainLoop,[syncByte] 'Does not work...
select case syncByte
case "S"
HSERIN2 250, MainLoop, [syncByte]
HSEROUT2 ["synByte=", #syncByte, 13,10]
'case = "A"
' hserin2 250, Main, [DEC syncByte]
' HSEROUT2 ["Case A=", #syncByte, 13,10]
'case = "B"
case else
HSEROUT2 ["syncByte=", #syncByte, 13,10]
end select
LED_CPUOverT = 0
Goto MainLoop
This code does not pass neighter the first instruction HSERIN2.
The LED just blink, I saw with a digital scope that data are on to the right pin... and nothing happen.
BUT:
removing the HSERIN2 line and putting instead the line with the Serin2:
SerIn2 PortG.2,84,1000,MainLoop,[syncByte] 'It work !!!
IT WORK!
Why the hardware serial port 2 does not work with the HSERIN2 ?
Maybe I've missed some register's settings or initialized in a bad sequence?
Thank you very much.
