Measuring voltage from a current transformer
The nice people over at CR magnets sent me over some samples of their 8010 current transformers to check out. I basically want to create a permanent amperage meter to be mounted to our main circuit panel.
Each line coming out of the breakers would have a current transformer around it so the user can select which circuit is being monitored.
I just need a kick in the right direction on how to measure the voltage from the CT and how to calculate the voltage in reference to what the actual amperage is in the primary line.
Thanks!
BTW i have a 16F737 kicking around, so I will probably be prototyping with it.
