Simple LCD code not working..
Hi all,
I have a couple of projects with 16F877a's and 4 line LCD panels working fine.
I wanted to do something smaller scale, and have a 16F84a and a 2x16 LCD. I have used this LCD in the past and it was fine. I have written a very short program just to get the LCD going, but alas it doesn't show anything... Below is my code:
define osc 4
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTB
DEFINE LCD_RSBIT 2
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 3
TRISA = %11111
butup var porta.0
butdn var porta.1
light var portb.1
light = 0
light = 1
lcdout $fe,1
Start:
lcdout $fe,$80,"line one"
lcdout $fe,$C0,"line two"
toggle light
goto Start
On turn-on, the LCD enables (1st row black boxes, 2nd row blank) then waits the 1000 and clears the LCD. After that, I get nothing at all on the LCD, but the led blinks away happily.
I've done this before on a 16F88 I think (albeit a while ago) which is why it is frustrating me so.
Can anyone point out anything I've done wrong in the code? Do I need to declare anything else, etc? I have checked and rechecked the wiring many times, if no-one can point out anything I will have to source and test another LCD incase that is the problem.
Thanks in advance.
