WRITE REAR eeprom Address ????'s
Hello,
I would like to know how to put the Address (for WRITE, READ command) in a for loop such that I can write once to adress 0, and then roll into adress 1 and so on. I have tried creating am variable but an not able to do this. Basically I am reading a POT 10x a second, sampling the data once and storing that sample in my eeprom, then reading the values back out to my LCD. I would like to use all 256 bytes of space in my eeprom while data logging.
It's probably a dumb question but....?
here is the snippet of my code that does work but is obviously a space waster
loop1:
LCDOUT 254,1
for a = 0 to 20
ADCIN 0, Value
wriTE 0, Value
y = ( Value *100 ) / 51 'divided down from * 255 / 130
LCDOUT 254,Row1,"LOG SENSOR ",DEC1 (y / 100 ),".",DEC2 ( y // 100 )," VDC"
lcdout 254,Row3+2, "0......|......5"
; syntax- BARgraph Value, Row, Col, Width, Range, Style
@ BARgraph _Value, 2, 2, 15, 255, lines
next a
'FIRST DATA SAMPLE
for b = 0 to 20
ADCIN 0, Value
wriTE 1, Value
next b
'SECOND DATA SAMPLE
for c = 0 to 20
ADCIN 0, Value
wriTE 2, Value
next c
'THIRD DATA SAMPLE
for d = 0 to 20
ADCIN 0, Value
wriTE 3, Value
next d
