ON INTERRUPT not working
My program runs OK the first time, but interrupt does not go to start. It wakes from sleep (clock is active) but just idles. What am I doing wrong? This is the program:
'* Notes : Power up starts the time and turns on a FET *
'* : switch. After 15 minutes, the FET switch is *
'* : is turned off. If the stop switch is pressed *
'* : while the timer is running, the FET is turned off;*
'* : and the timer goes to sleep. The start switch *
'* : (interrupt) wakes the timer and starts it. *
REM device = 12F675
CMCON = 7 ' SETS DIGITAL MODE
ANSEL = 0 ' GPIO.0 TO GPIO.3 SET AS DIGITAL
OPTION_REG = 0 ' WEAK PULLUPS ENABLED
TRISIO = %00001100 ' GPIO.2 AND GPIO.3 SET AS INPUT
IOC = %00000100 ' INTERRUPT ENABLED ON GPIO.2
VRCON.7 = 0 ' TURN OFF VOLTAGE REFERENCE
N VAR WORD ' VARIABLE N DEFINED
ON INTERRUPT GOTO AGAIN
INTCON = %10010000 ' INTERRUPT ENABLED
START:
INTCON.1=0 ' Clear GP2/INT flag
HIGH GPIO.0
FOR N=1 TO 900
IF GPIO.3=0 THEN SLEEPNOW
PAUSE 1000
NEXT N
SLEEPNOW:
LOW GPIO.0
SLEEP 1 ' WDT is turned off so I think it does not wake uP.
AGAIN:
GOTO START
resume
Hi,Russ
Just a minute ... I'm looking for a solution, and then will explain you the "why"
Hi, Russ
That should run ...
REM device = 12F675
OPTION_REG.7 = 0 ' WEAK PULLUPS ENABLED
GPIO = %00001100
PAUSE 300 'let's supply stabilize ...
Start:
N = 0
HIGH GPIO.0 'Lit The Light
While ( N < 3126 AND GPIO.3 ) ' Do that while GPIO.3 is High
' AND time not finished
NAP 4 'Sleep for .288 sec
N = N+1
WEND ' We've read enough !!!
LOW GPIO.0 'Ligts off !!!
INTCON = %00010000 ' INTERRUPT ENABLED ON GPIO.2, but NOT GIE !!!
@ Sleep ;Real ASM sleep
@ nop
INTCON.1 = 0 'cancel interrupt flag
GOTO Start
Thank you. I see you don't like the "on interrupt" command; I don't either any more.
I tried your program and it works exactly the same as mine: the first pass is OK but interrupt does not go to start.
Any other thoughts?
Russ
ON INTERRUPT will work, it just need some care when you write your code. But sometimes, you don't need to use it.
OH, my. I found part of my problem: I was loading the hex file from the Melabs folder but Microcode Studio was saving in a different folder. No wonder nothing I did made any difference! I will have to start over and do it again.
BTW, your program does not go to sleep, at least not in 20 minutes.
Russ
Hi, Russ
THAT Works ( in the real World ...LOL ) ... but, for the moment, I Can't use GPIO.3 !!!
so, it works with GPIO.4 ...
I'm digging for what I've forgotten ...
REM device = 12F675
'DEVICES------------------------------------------------------------------
@ __Config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF
ADCON0 = 0
WPU = %00011100
GPIO = %00011100
TRISIO = %00011100 ' GPIO.2 AND GPIO.3 SET AS INPUT
INTCON = 0
Start:
N = 0
While ( N < 3126 ) AND GPIO.4 ' Do that while GPIO.4 is High 3126
PAUSE 288 'Pause for .288 sec
N = N+1
@ nop
INTCON = 0 'Interrupt disabled
GOTO Start
PS : May be GPIO.3 is "locked" by the reset system of my EasyPic5 ???
rePS : YESS ... works fine with GPIO.3 ... when J7 is correctly set !!!
