LM135 voltage ref
Hi everyone,
I'm trying to study a pic based thermometer using LM135 and PIC16F876A, but the display value is jumping from high to low, I think it has something to do with the voltage reference but I'm not really sure how it must be done. Please check my schematic and codes that I'm using.
CLEAR
DEFINE ADC_BITS 8
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
TRISA = %11111111
ADCON1 = %00000011 ' Set PORTA.0,1,2,5 = A/D, PortA.3 = +Vref
samples VAR WORD ' Multiple A/D sample accumulator
sample VAR byte ' Holds number of samples to take
temp VAR byte ' Temperature storage
samples = 0 ' Clear samples accumulator on power-up
LOOP:
FOR sample = 1 TO 20 ' Take 20 samples
ADCIN 0, temp ' Read channel 0 into temp variable
samples = samples + temp ' Accumulate 20 samples
PAUSE 250
NEXT sample
temp = samples/20
Serout PortC.1, 6, [$FE, 1, #temp]
samples = 0
GOTO loop
Thanks in advance,
joe
Try a capacitor between the signal pin of LM and ground. 22uF?
Let's see
Ambient temp is ~ 300°K LM 135 outputs 3v
ADC Counts = 3/5*256 = 153 ... that's OK
mmmmmmh, what about connecting AN3 input to Vss ... and making it an input (!)
or MUCH BETTER correcting your ADCON1 settings ...
cause , for now, you do not have any Vref at all ...
AND you've forgotten to connect the second GND ( or VSS ) PIN !!!
