Hi all,
I would like to ask if it's possible to convert Hex file to assembly or picbasic file ??
Hi all,
if you search, you'll find a couple disassemblers/decompilers that will turn the hex into asm. There aren't any that convert to basic, or any other high-level language, due to the complexity.
thanks you tenaja but I don't find any results when searching, so if you can help me about some links or programms
Hi, Iugmoh
Just download MPLAB !!!
- View\Program Memory
- File \Import
Choose the "Machine" or "Symbolic" Tab, at the left Bottom of the window ...
BUT:
- Labels and aliases can't be displayed ( not stored by the Hex File ) ... so, it's difficult to add lines without a GOTO-GOTO jumper; lines removed must be replaced by a NOP or equ.
DO NOT CHANGE THE LINE NUMBERS !!! without exactly knowing what you are doing ...
Only real interest is to translate strings, or add a part ( or 2 , or 3 ) of program at the end of the listing.
to save : right click, and " save as " progmod.txt " ...
Do not wait for miracles ... like get some PbP files !!!
thanks Acetronics
