Hello!
I've got a problem with my Assembler. When I use the built-in assembler with the 16 series, it works fine, but it's not working with the 18 series. So for this cases I use the external MPLab 8.0 Suite assembler made by Microchip. But with this, my programs using the 16 series PIC doesn't work properly. Since I usually forget to switch between them when changing the PIC and the program, it happens quite a lot. There are differences even in the hex files.
Is there any way to fix the assembler problem or the only way is to stick a paper on my monitor telling me to check the assembler settings?
With regards
Joe
