Temp readings and voltage input
Hi all,
i'm my 16F88 temp monitor project i have a LM35 sensor with no vref.
The input voltage for the workbench was always 5v and everything is working perfectly.
After moving for the pcb i have found an issue that puzzled me.
For the PCB aplication i have it connected ( via 7805 ) to a 4.8V NiCd pack. This pack when fully loaded is 5.3V and after some use it drops to +-4.5V.
This is causing some bad temperature readings when the pack drops bellow 5v.
The code i used for temperature is like this :
temp= (in */5000)>>2
I have no vref because i can live with the 0.5ºC stepping ( 10Bit resolution ) and this code allows me to have an output like XXX,X.
My question is:
Is there a better code to be flexible with the input voltage and still have accurate readings ?
The goal, always look for the goal ....
Ha,ha,ha ...
I think VENOM might tell you something !!!
Now, this would be much easier to use a NTC Thermistor or a KTY 81-1xx NTC sensor.
Just use a Lookup table with a linear regression between points ... and HOP, in the pocket ( as told the Kangaroo ... )
BTW ... choose your "gas" carefully ... lots of degrees to win here !!!
see :
http://www.carburant-modelisme.com/
and
http://www.meccamo.com/fr/indexFR.htm
for really serious blenders ...
