Setting up internal clock correctly?
I'm using an 18F2523 with PBP 2.50a (see setup below). I'd like to use the internal 8MHz clock so I can skip using a crystal and use those 2 pins for digital I/O. I've set up the PIC as follows but have a curious result when I do a DEBUG BIN8 OSCCON. The result is 01110111.
Wouldn't IOFS, that is OSCCON<2>, be set to high if the PIC was running correctly? Or is that bit only set high if a divider is used?
Thanks for your help!
John
' system setup
;---[CONFIG1H]------------------------------------------------------------------
CFG_1H = _OSC_INTIO67_1H ;int osc block, port function on RA6+RA7
CFG_1H = CFG_1H & _IESO_OFF_1H ;oscillator switchover mode disabled
;---[CONFIG2H]------------------------------------------------------------------
CFG_2H = _WDT_ON_2H ;WDT enabled
CFG_2H = CFG_2H & _WDTPS_512_2H ;WDT postscaler = 1:512
;---[CONFIG3H]------------------------------------------------------------------
CFG_3H = _PBADEN_ON_3H ;PORTB<4:0> are analog inputs on RESET
CFG_3H = CFG_3H & _MCLRE_ON_3H ;MCLR pin enabled, RE3 input pin disabled
;---[CONFIG4L]------------------------------------------------------------------
CFG_4L = _LVP_OFF_4L ;Single-supply ICSP disabled
CFG_4L = CFG_4L & _XINST_OFF_4L ;Legacy mode for inst. set and indexing
__CONFIG _CONFIG1H, CFG_1H ;store CONFIGs
__CONFIG _CONFIG2H, CFG_2H
__CONFIG _CONFIG3H, CFG_3H
__CONFIG _CONFIG4L, CFG_4L
DEFINE OSC 8 '8MHz clock
OSCCON = %01110011 'internal 8MHz clock
Very strange config Options ...
here are the MPASM config Options ... just choose yours !!!
; The following is an assignment of address values for all of the
; configuration registers for the purpose of table reads
_CONFIG1H EQU H'300001'
_CONFIG2L EQU H'300002'
_CONFIG2H EQU H'300003'
_CONFIG3H EQU H'300005'
_CONFIG4L EQU H'300006'
_CONFIG5L EQU H'300008'
_CONFIG5H EQU H'300009'
_CONFIG6L EQU H'30000A'
_CONFIG6H EQU H'30000B'
_CONFIG7L EQU H'30000C'
_CONFIG7H EQU H'30000D'
;----- CONFIG1H Options --------------------------------------------------
_OSC_LP_1H EQU H'F0' ; LP oscillator
_OSC_XT_1H EQU H'F1' ; XT oscillator
_OSC_HS_1H EQU H'F2' ; HS oscillator
_OSC_RC_1H EQU H'F3' ; External RC oscillator, CLKO function on RA6
_OSC_EC_1H EQU H'F4' ; EC oscillator, CLKO function on RA6
_OSC_ECIO6_1H EQU H'F5' ; EC oscillator, port function on RA6
_OSC_HSPLL_1H EQU H'F6' ; HS oscillator, PLL enabled (Clock Frequency = 4 x FOSC1)
_OSC_RCIO6_1H EQU H'F7' ; External RC oscillator, port function on RA6
_OSC_INTIO67_1H EQU H'F8' ; Internal oscillator block, port function on RA6 and RA7
_OSC_INTIO7_1H EQU H'F9' ; Internal oscillator block, CLKO function on RA6, port function on RA7
_FCMEN_OFF_1H EQU H'BF' ; Fail-Safe Clock Monitor disabled
_FCMEN_ON_1H EQU H'FF' ; Fail-Safe Clock Monitor enabled
_IESO_OFF_1H EQU H'7F' ; Oscillator Switchover mode disabled
_IESO_ON_1H EQU H'FF' ; Oscillator Switchover mode enabled
;----- CONFIG2L Options --------------------------------------------------
_PWRT_ON_2L EQU H'FE' ; PWRT enabled
_PWRT_OFF_2L EQU H'FF' ; PWRT disabled
_BOREN_OFF_2L EQU H'F9' ; Brown-out Reset disabled in hardware and software
_BOREN_ON_2L EQU H'FB' ; Brown-out Reset enabled and controlled by software (SBOREN is enabled)
_BOREN_NOSLP_2L EQU H'FD' ; Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
_BOREN_SBORDIS_2L EQU H'FF' ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
_BORV_0_2L EQU H'E7' ; Maximum setting
_BORV_1_2L EQU H'EF' ;
_BORV_2_2L EQU H'F7' ;
_BORV_3_2L EQU H'FF' ; Minimum setting
;----- CONFIG2H Options --------------------------------------------------
_WDT_OFF_2H EQU H'FE' ; WDT disabled (control is placed on the SWDTEN bit)
_WDT_ON_2H EQU H'FF' ; WDT enabled
_WDTPS_1_2H EQU H'E1' ; 1:1
_WDTPS_2_2H EQU H'E3' ; 1:2
_WDTPS_4_2H EQU H'E5' ; 1:4
_WDTPS_8_2H EQU H'E7' ; 1:8
_WDTPS_16_2H EQU H'E9' ; 1:16
_WDTPS_32_2H EQU H'EB' ; 1:32
_WDTPS_64_2H EQU H'ED' ; 1:64
_WDTPS_128_2H EQU H'EF' ; 1:128
_WDTPS_256_2H EQU H'F1' ; 1:256
_WDTPS_512_2H EQU H'F3' ; 1:512
_WDTPS_1024_2H EQU H'F5' ; 1:1024
_WDTPS_2048_2H EQU H'F7' ; 1:2048
_WDTPS_4096_2H EQU H'F9' ; 1:4096
_WDTPS_8192_2H EQU H'FB' ; 1:8192
_WDTPS_16384_2H EQU H'FD' ; 1:16384
_WDTPS_32768_2H EQU H'FF' ; 1:32768
;----- CONFIG3H Options --------------------------------------------------
_MCLRE_OFF_3H EQU H'7F' ; RE3 input pin enabled; MCLR disabled
_MCLRE_ON_3H EQU H'FF' ; MCLR pin enabled; RE3 input pin disabled
_LPT1OSC_OFF_3H EQU H'FB' ; Timer1 configured for higher power operation
_LPT1OSC_ON_3H EQU H'FF' ; Timer1 configured for low-power operation
_PBADEN_OFF_3H EQU H'FD' ; PORTB<4:0> pins are configured as digital I/O on Reset
_PBADEN_ON_3H EQU H'FF' ; PORTB<4:0> pins are configured as analog input channels on Reset
_CCP2MX_PORTB_3H EQU H'FE' ; CCP2 input/output is multiplexed with RB3
_CCP2MX_PORTC_3H EQU H'FF' ; CCP2 input/output is multiplexed with RC1
;----- CONFIG4L Options --------------------------------------------------
_STVREN_OFF_4L EQU H'FE' ; Stack full/underflow will not cause Reset
_STVREN_ON_4L EQU H'FF' ; Stack full/underflow will cause Reset
_LVP_OFF_4L EQU H'FB' ; Disabled
_LVP_ON_4L EQU H'FF' ; Enabled
_XINST_OFF_4L EQU H'BF' ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
_XINST_ON_4L EQU H'FF' ; Instruction set extension and Indexed Addressing mode enabled
_DEBUG_ON_4L EQU H'7F' ; Background debugger enabled, RB6 and RB7 are dedicated to In-Circuit Debug
_DEBUG_OFF_4L EQU H'FF' ; Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
;----- CONFIG5L Options --------------------------------------------------
_CP0_ON_5L EQU H'FE' ; Block 0 (000800-001FFFh) code-protected
_CP0_OFF_5L EQU H'FF' ; Block 0 (000800-001FFFh) not code-protected
_CP1_ON_5L EQU H'FD' ; Block 1 (002000-003FFFh) code-protected
_CP1_OFF_5L EQU H'FF' ; Block 1 (002000-003FFFh) not code-protected
_CP2_ON_5L EQU H'FB' ; Block 2 (004000-005FFFh) code-protected
_CP2_OFF_5L EQU H'FF' ; Block 2 (004000-005FFFh) not code-protected
_CP3_ON_5L EQU H'F7' ; Block 3 (006000-007FFFh) code-protected
_CP3_OFF_5L EQU H'FF' ; Block 3 (006000-007FFFh) not code-protected
;----- CONFIG5H Options --------------------------------------------------
_CPB_ON_5H EQU H'BF' ; Boot block (000000-0007FFh) code-protected
_CPB_OFF_5H EQU H'FF' ; Boot block (000000-0007FFh) not code-protected
_CPD_ON_5H EQU H'7F' ; Data EEPROM code-protected
_CPD_OFF_5H EQU H'FF' ; Data EEPROM not code-protected
;----- CONFIG6L Options --------------------------------------------------
_WRT0_ON_6L EQU H'FE' ; Block 0 (000800-001FFFh) write-protected
_WRT0_OFF_6L EQU H'FF' ; Block 0 (000800-001FFFh) not write-protected
_WRT1_ON_6L EQU H'FD' ; Block 1 (002000-003FFFh) write-protected
_WRT1_OFF_6L EQU H'FF' ; Block 1 (002000-003FFFh) not write-protected
_WRT2_ON_6L EQU H'FB' ; Block 2 (004000-005FFFh) write-protected
_WRT2_OFF_6L EQU H'FF' ; Block 2 (004000-005FFFh) not write-protected
_WRT3_ON_6L EQU H'F7' ; Block 3 (006000-007FFFh) write-protected
_WRT3_OFF_6L EQU H'FF' ; Block 3 (006000-007FFFh) not write-protected
;----- CONFIG6H Options --------------------------------------------------
_WRTB_ON_6H EQU H'BF' ; Boot block (000000-0007FFh) write-protected
_WRTB_OFF_6H EQU H'FF' ; Boot block (000000-0007FFh) not write-protected
_WRTC_ON_6H EQU H'DF' ; Configuration registers (300000-3000FFh) write-protected
_WRTC_OFF_6H EQU H'FF' ; Configuration registers (300000-3000FFh) not write-protected
_WRTD_ON_6H EQU H'7F' ; Data EEPROM write-protected
_WRTD_OFF_6H EQU H'FF' ; Data EEPROM not write-protected
;----- CONFIG7L Options --------------------------------------------------
_EBTR0_ON_7L EQU H'FE' ; Block 0 (000800-001FFFh) protected from table reads executed in other blocks
_EBTR0_OFF_7L EQU H'FF' ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
_EBTR1_ON_7L EQU H'FD' ; Block 1 (002000-003FFFh) protected from table reads executed in other blocks
_EBTR1_OFF_7L EQU H'FF' ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
_EBTR2_ON_7L EQU H'FB' ; Block 2 (004000-005FFFh) protected from table reads executed in other blocks
_EBTR2_OFF_7L EQU H'FF' ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
_EBTR3_ON_7L EQU H'F7' ; Block 3 (006000-007FFFh) protected from table reads executed in other blocks
_EBTR3_OFF_7L EQU H'FF' ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
;----- CONFIG7H Options --------------------------------------------------
_EBTRB_ON_7H EQU H'BF' ; Boot block (000000-0007FFh) protected from table reads executed in other blocks
_EBTRB_OFF_7H EQU H'FF' ; Boot block (000000-0007FFh) not protected from table reads executed in other blocks
somewhat different from yours ... no ???
use the "regular" scripting ... that's all !
