Vista 64 bit OS Compiling
I been learning how to program PICs such as the P16F84A in school lately and been really enjoying it. We have Windows XP and use CDlite and PBC 1.45 currently and the software works fine.
I wanted to expand and decided to purchase what I needed to learn away from school since this is my final semester. I bought the Melabs U2 Programmer and am using PicBasic Compiler. Problem is I use Vista 64 bit at home. The programmer works fine and can read and write to the PICs. I just cannot compile with the current version of PicBasic. I get compatiablity error and am asked to get a 64 bit version. I have tried different compatiability modes but I don't think that will help since its 16bit.
Anyone know of a work-a-round other than installing WinXP? Is there a newer version of a PIC compiler out there? Also looking to set up assembly and C++ compiling too.
PDS & Spark Technologies SparKey Drivers - VISTA x64 WORKS!
Simply use "ReadyDriver Plus", this tool automates pressing F8 and selecting "Disable Driver Signature Enforcment" during boto in Vista, a perfect solution.
http://citadel.x10hosting.com/readydriverplus/index.php
I tested this using files provided by "Lester Wilson" from crownhill as below:
http://www.picbasic.org/forum/attach...7&d=1190881109
A simple temp solution untill somone can be bothered to sign the drivers, which i must add is not exactly the most complicated of tasks:
http://www.vistax64.com/vista-genera...vista-x64.html
Paul Freer
PF Technology Ltd
Leicester, UK
3 Attachment(s)
PDS/SparKey & VISTA X64 > IT WORKS > Compilation Success!!
I can confirm that I have PDS and the SparKey dongle DO WORK on Vista x64
For the following files listed below; SET Properties > Compatibility > Privilege Level > “Run this program as an administrator”.
C:\Program Files (x86)\Crownhill\PDS\APP.exe
C:\Program Files (x86)\Crownhill\PDS\OPT.exe
C:\Program Files (x86)\Crownhill\PDS\PR_PLUS.exe
C:\Program Files (x86)\Crownhill\PDS\PR_PLUS_MPLAB.exe
C:\Program Files (x86)\ProtonIDE\ProtonIDE.exe
Ensure your dongle is enabled and working in device manager; following the details given in last post. P.S. You should have “sparkey.inf” in “C:\Windows\inf” AND “sparkey.sys” in “C:\Windows\System32\drivers”.
Processor: Intel(R) Core(2TM)2 CPU 6600 @ 2.4GHz
Memory (RAM): 2.00 GB
System Type: 64-bit Operating System
Anyway what am I doing up at 4pm on a Sunday trying to fix this silly problem, nite!!
Hail All
__________________
Paul Freer
PF Technology Ltd
51 Fairefield Crescent
Glenfield
Leicester
LE3 8EJ
