the ultrasonic SRF04 with pic16f88
hello everybody
I have few problems with my ultrasonic ranger the SRF04.
I managed to make it work with a pic 16f84 to measure distances in inches and centimeters and display the results on a serial lcd. worked really fine.
then i tried to use the pic 16f88 with an internal clock ; but the lcd displays 0cm and 0 inches all the time which means that the SRF04 is not doing the job (the internal clock is working by the way. i tested it with another code)
here is a part of my code in picbasic pro:
INTRC_OSC_NOCLKOUT
INTRC_IO
OSCCON=%01101000
include "modedefs.bas"
trisa = %11111111
trisb = %00000000
lcd var portb.7
'piezo var portb.4
trigger var portb.6
echo var porta.0
baud con N2400
dist_raw var word
dist_inch var word
dist_cm var word
conv_inch con 15
conv_cm con 6
low trigger
serout lcd,baud,[254,1] 'clear lcd screen
serout lcd,baud,[254,128,"-sonar ranger-"]
'sound piezo,[100,10,50,5,70,10,50,2] 'make startup sound
pause 1000 'pause 1 sec
serout lcd,baud,[254,128,"inches: "] 'set up the lcd display
serout lcd,baud,[254,192,"centimeters: "]
gosub sr_sonar
serout lcd,baud,[254,135,#dist_inch," "] 'display the disance in inches
serout lcd,baud,[254,204,#dist_cm," "] 'display the distance in cm
sr_sonar:
pulsout trigger,1 'send a 10us trigger pulse
pulsin echo,1,dist_raw 'start timing the pulse width
'on echo pin
dist_inch = (dist_raw/conv_inch)
dist_cm = (dist_raw/conv_cm)
pause 1
i suppose that the pins of the pic are not inputing or outputing the right datas. may be because i did not set the input and output properly.
i had been strogling for few days , please help me to make it work.
thanx
regards
which bit fixed the problem
skimask
Just curious...which bit fixed the problem?
Invariably, it's usually that one little bit that fixes everything...
those 6 lines allowed me to use an accurate inside clock and to use all pins as digital input or outputs:
INTRC_OSC_NOCLKOUT
INTRC_IO
OSCCON=%01101000
ANSEL=%00000000 'this comand disable all adc
CMCON=%00000111 'this bit disable all comparators
the two last commands fixed the problem to get just digital inpout and outpout on all 15 pins available, and disabled all adc and comparators.
