Hello,
I've tried to use PWM in 10bits mode for the first time and (almost) everything works fine.
Making some measurements, I notice that the PWM frequency doesn't reach 1kHz as it should (in my opinion). I get around 0,975kHz instead.
Is this due to my 4MHz XTal's or what?
Code:' PIC 16F690 Fuses
@ DEVICE FCMEN_OFF
@ DEVICE IESO_OFF
@ DEVICE BOD_ON
@ DEVICE CPD_OFF
@ DEVICE PROTECT_OFF
@ DEVICE MCLR_OFF
@ DEVICE PWRT_OFF
@ DEVICE WDT_OFF
@ DEVICE HS_OSC
' Registers 76543210
OPTION_REG = %10000101 'PORT A&B Pull-Ups disabled (look WPUA & WPUB)
ANSEL = %00010100 'Select analog inputs Channels 0 to 7
ANSELH = %00000010 'Select analog inputs Channels 8 to 11
ADCON0 = %00000001 'A/D Module is ON (Bit5:2 select channels 0:11)
ADCON1 = %00000000 'A/D control register
CM1CON0 = %00000000 'Comparator1 Module is OFF
CM2CON0 = %00000000 'Comparator2 Module is OFF
INTCON = %10100000 'INTerrupts CONtrol (TMR0 ON)
TRISA = %00000000 'Set Input/Output (0 to 5)
PORTA = %00000000 'Ports High/Low (0 to 5)
TRISB = %00000000 'Set Input/Output (4 to 7)
PORTB = %00000000 'Ports High/Low (4 to 7)
TRISC = %00000000 'Set Input/Output (0 to 7)
PORTC = %00000000 'Ports High/Low (0 to 7)
' HPWM registers
T2CON = %00000101 'Timer2 = ON (bit2), prescaler = 4
CCP1CON = %00001100 'Select PWM Mode
CCPR1L = 0
CCP1CON.5 = 0
CCP1CON.4 = 0
PR2 = 255
DutyCl var word
dutycl = 856
TEST:
CCPR1L = dutycl >> 2
CCP1CON.5 = Dutycl.1
CCP1CON.4 = Dutycl.0
goto test
