I'm trying to understand what is typically done to clean and dry pcb's.
I'm using a water soluable solder paste from Stencils Unlimited.
http://www.stencilsunlimited.com/pro...roducts_id=179
After soldering, I use soapy water with a tooth brush to remove the flux residue. This works pretty well and is similiar to the much suggested
"just put the pcb's in the dishwasher to clean them"
But then how best to safely dry them? I've read that using compressed air is good enough?
Or should they be dried in the oven for a day or two at a low temperature ~ 80 to 90 celsius?
