Math operations & Syntax?
I'm a bit confused on the actual use and syntax when using WORD sized variables.
I'm going to measure a timed event, then use that time as a basis for a pass/fail trial of another timed event. I need to measure the time (16-bit), then manipulate it (subtract a few microseconds), then use that manipulated result to continually pre-load the timer and see if the event happens again within the similar allotted time frame.
Here is what I plan to do and how I will syntax it - wanted to see if I'm doing this correctly?
Using TMR1 ...
'Variables
tMeasure VAR WORD 'Holder for the time
tResult VAR WORD 'Holder for modified time
tSet VAR WORD 'Holder for timer set value
'Measure event, manipulate Data
T1CON.0=0 'Stop timer
TMR1H = %00000000 'Reset the timer
TMR1L = %00000000 '......
PIR1.0=0 'Clear timer overflow bit
T1CON.0=1 'Start timer
''' Wait for event to measure
T1CON.0=0 'Stop Timer
tMeasure = TMR1 'Should put timer stop value into tMeasure
tResult = tMeasure - 100 'Subtract 100 cycles
tSet = 65025 - tResult 'Setpoint for timer
'' If I pre-load the timer with this tSet number, then wait
'' for it to time out, it should run for a time period in cycles
'' equal to tResult - right?
'Perform trial timeout
TMR1 = tSet
WHILE PIR1.0=0 : WEND
TOGGLE probe 'Should happen about tResult cycles after
'starting the timer, yes?
My real questions are with the manipulation of the 16-bit variables. When I write "TMR1 = tSet", the TMR1H and TMR1L registers are filled correctly with the high byte and low byte of tSet - correct?
Normally I would set TMR1 by manually setting the TMR1H and TMR1L with binary code like "TMR1H = %11101100".
Also, do I need to worry about which direction the data is justified? I know it's important, but if I do it as written, is PBP smart enough to get the justification correct for me?
Thank you!
