Serial reading of binary at 75 baud
I wonder if anyone may be able to help...
I am using an 18F1320 at 4Mhz and need to read serial binary code at 75 baud. I then need to convert the binary 'back' into Hex to output at a faster rate which is no problem. I can read at 75 baud using a 4MHz crystal by DECLARING it at 16MHz and using SERIN, but then have a problem with the input being in binary....
Thanks for the reply Skimask,
Maybe I am missing something here, I cant find a SERIN2 command in the manual. Well, it is found on the back page as a protected word...
You are right in what I have coming in is something like %01010011.
As I understand thing, the following code would not be looking for BIN input, but ASCII? Which can then be represented as required....?
Dim InDat as Byte
Serin2 PORTB.4, 19697, [InDat]
The results printed as HEX are not what I am expecting, I think 00 80 00 00 ???
I was starting to think the same! But yes....
Proton Development Suite
I am running Proton+ Basic compiler 3.1.0.9
