How to read AC mains with an inductance coil
Can anyone point me to an example circuit of how to read AC with an inductance coil
and have PBP interpret the fact that AC voltage has turned on in the AC mains wire?
I'd like to use the most basic of PICs... 12C509 or F84 or 628...what I have here now on the bench.
total disconnect from the AC being sensed
I wanted to sense if the AC current was ON without actually tapping into the AC circuit.
I was thinking of how a clamp-on ammeter does not make actual contact with the
AC current but does actuate a meter needle to swing.
I just want an ON OFF detection that can fire off a relay or a PIC to be able to sense that ON OFF in PBP.
yes but how to use it in PBP
YEs...this is what I was thinking but I don't know how to have PBP
interface this inductance coil.
I'm a programmer, not an electronics engineer, so I am at a loss as to
what PBP command to use with this coil from coilcraft.
My first thought was to do PULSIN but I do not know the proper way to wire
PULSIN to an inductor coil.
Any example or advice how to wire and read the COILCRAFT coil output?
