Found mistake on design homepage
Hi Guys!
This works:
' 16F628A 20Mhz extern canned Oscillator
' damn program should blink an LED
' Yeah Works!
@config_EXTCLK_OSC
DEFINE OSC 20
LED VAR PORTB.7
CMCON = 7 ' RA0-RA3 are digital I/O
TRISB = %01111111 ' RB7 is output, rest are inputs.
led = 1
led = 0
END ' End of program
And heres the mistake:
http://hobby_elec.piclist.com/e_pic8_8.htm
Look at the osc wiring diagram: ext osc MUST be connected to RA6! hahahaha!
osc setting manually no go
Hi Joe,
iīm using the PicKit2 and i didnīt find any osc settings in the programmer window. That was what I tried at first.
had the Velleman programmer before and this had the possibility to set osc configs. But that one died long ago.....simply didnt work anymore.
on the other hand: PicKit2 is fast an easy to use and supports everything, even the 16F628A...hahaha
