Simple 4 channel DMX controller
'simple 4 channel DMX controller
'reads 4 potmeters to control 4 lights
'08-02-08 Kees Reedijk
@ DEVICE PIC16F88, MCLR_OFF, HS_OSC, WDT_ON, LVP_OFF, PWRT_ON
DEFINE OSC 20 ' 20MHZ crystal
DEFINE ADC_BITS 8 ' Set number of bits
DEFINE ADC_CLOCK 3 ' Set clock source
DEFINE ADC_SAMPLEUS 50 ' Set sampling time
DEFINE HSER_SPBRG 4 ' 250 KBaud
RCSTA=%01010000 '9 bit data,usart disabled
TXSTA=%01100101 'Enable transmit, BRGH=1, 9 bit data
PORTA= %00000000
TRISA= %00001111
PORTB= %00100000
TRISB= %00000100
ANSEL= %00001111
CMCON= %00000111
DMX VAR PORTB.5 'DMX output to SN75176 bus driver
level1 VAR BYTE
level2 VAR BYTE
level3 VAR BYTE
level4 VAR BYTE
CLEAR
loop:
ADCIN 0,level1 'read level potmeters
ADCIN 1,level2
ADCIN 2,level3
ADCIN 3,level4
LOW DMX
PAUSEUS 100
HIGH DMX
PAUSEUS 12
RCSTA.7=1 'usart enabled
HSEROUT [0,level1,level2,level3,level4]
PAUSE 10
RCSTA.7=0 'usart disabled
GOTO loop
Re: Simple 4 channel DMX controller
This thread code looks goofed up any chances of including a txt file for the benefit of others.
Thanks.
The vertical scroll bar is missing in the code area! So I can see only the few initial Lines of the code.
From what i understand reading the various Posts, it seems I am the only one with this problem.
Al.
Is anyone else missing the scroll bars? I can see them.
I see them fine.
maybe is your browser Al. Try some other, Opera for instance. I test it and seems a little faster that IE9.
Ok thanks. Problem seems to be with ipad browser, I can see it with firefox.
Al.
Hi Al. assuming your iPad is like my iPhone, have you tried to "2 finger scroll" in the code window? On my phone I get no bars, but I can scroll the code windows using 2 fingers.
Tank you Bert for the tip. 2 finger scroll in the code window works fine.
Cheers
Al.
_Isthissoftwareworks the same wayhserin ?
The DMX protocol uses 250k baud RS-485. There are some start pulses and such that need to happen. That what the HIGH/LOW DMX and pauses are doing. Here's an app note from Microchip that explains a bit more about it http://ww1.microchip.com/downloads/e...tes/01076A.pdf
What is language? Basic?, C?, mikrobasic? Please help-me! thanks
Depends which one you are talking about. The first post example is in PicBasic (check out www.melabs.com for software). The application note example for AN1076 is in assembly: http://www.microchip.com/stellent/id...pnote=en527825
personally... i hate the DMX protocol... but i'm sure their is a reason for it...
running at 250K baud is going to be fun for anyone new...
I recommend double buffering the data and using interrupts both for the USART and the ADC... ;)
