Simultaneous outputs
Just starting out with the PIC's and don't understand why I can't get three LED's to all flash on and off at a 1/2 second rate. Using 12F675 with PBP with the following code:
Start: HIGH 0
HIGH 1
HIGH 2
PAUSE 500
LOW 0
LOW 1
LOW 2
PAUSE 500
GOTO Start:
With this code GPIO.0 goes on and off at a ~1.7mS rate. GPIO.1 and GPIO.2 are always off. Shouldn't all three go on and off?
I can rewrite the code and drop off the first pause and put the GOTO in it's place and all three will come on and stay on as expected.
All three outputs can be programmed individually to flash in any order or rate.
Looking for ideas please?
The HIGH & LOW commands take care of the TRIS registers for you to make your I/O-pins outputs, but they don't take care of certain built-in hardware peripheral features.
In this case, that would be the onboard comparator & A/D modules.
Try this;
CMCON = 7 ' Comparators off
ANSEL = 0 ' A/D off, set I/O to all digital
Start:
HIGH 0
HIGH 1
HIGH 2
PAUSE 500
LOW 0
LOW 1
LOW 2
PAUSE 500
GOTO Start
Take a peek in the datasheet under the Comparator Module & Analog-to-Digital sections to see why this makes it work.
Thanks Bruce, that cleared up everything. I didn't find it in the config. setup as an option in the MicroCode Studio. Will code it in as necessary from now on. FB
You can also do your task in less line and it will take less of your code space.
CMCON = 7
ANSEL = 0
Start:
GPIO=7
PAUSE 500
GPIO=0
PAUSE 500
GOTO Start
Close, but you forgot to configure your pins as outputs.
All I/O-pins are inputs on power-up by default.
This would work.
CMCON = 7
ANSEL = 0
TRISIO = 0 ' GPIO = outputs
Start:
GPIO=7
PAUSE 500
GPIO=0
PAUSE 500
GOTO Start
And if you're really stingy on code space, you could do it something like this;
CMCON = 7
ANSEL = 0
GPIO = 7
Start:
GPIO = GPIO ^ 7 ' Toggle GPIO.0, 1 and 2
PAUSE 500
GOTO Start
well done again Bruce. I was aware of this TRSIO line since i've never use this before considering that PBP was suppose to do. But after experimenting i realise that was important to include in this case. I'll use this TRIS in future as a safe programming way.
that's for sure there's many way to blink a led. XOR function are one example :). code also working without GPIO=7 but it's also a safe way.
Wow , many ways of doing things better with the first lines of code. Great eye opener. Thans to the group. FB
