Elapsed_Int-18 Alteration
I've added a slight alteration to Darrel's Elapsed_Int-18 to get 48MHz oscillator. Could somebody please check if this is correct?
' To calculate a constant for a different crystal frequency - see this web page
' http://www.picbasic.co.uk/forum/showthread.php?t=2031
Asm
IF OSC == 4 ; Constants for 100hz interrupt from Timer1
TimerConst = 0D8F7h ; Executed at compile time only
EndIF
If OSC == 8
TimerConst = 0B1E7h
EndIF
If OSC == 10
TimerConst = 09E5Fh
EndIF
If OSC == 16
TimerConst = 063C7h
EndIF
If OSC == 20
TimerConst = 03CB7h
EndIF
If OSC == 48 ; If an oscillator of 48MHz is used e.g.
TimerConst = 015A4h ; in USB PICs, set TimerConst to 015A4h.
BSF T1CON,T1CKPS0, 0 ; MUST also set to prescale of 2 NOT 1
EndIF
; ----------------- ADD TimerConst to TMR1H:TMR1L
ADD2_TIMER macro
; CHK?RP T1CON
BCF T1CON,TMR1ON, 0 ; Turn off timer
MOVLW LOW(TimerConst) ; 1
ADDWF TMR1L,F, 0 ; 1 ; reload timer with correct value
BTFSC STATUS,C ; 1/2
INCF TMR1H,F, 0 ; 1
MOVLW HIGH(TimerConst) ; 1
ADDWF TMR1H,F, 0 ; 1
The timer seems to run doubly quick like the prescale setting is not being set correctly. If I set the prescale setting in the ADD2_TIMER macro though it works correctly but will increase the amount of instructions required therefore altering the amount of time a tick takes:
ADD2_TIMER macro
; CHK?RP T1CON
If OSC == 48 ; IF OSCILLATOR IS 48MHz THEN
BSF T1CON,T1CKPS0, 0 ; SET PRESCALE VALUE TO 2
EndIF
INCF TMR1H,F, 0 ; 1
Thanks in advance
Rob
