I don't know how to do that quote thing or I'd post my code in a thread. I started out writing a simple program to increase and decrease a timer based upon button inputs. When I do the increase, everything works great. When I hit the button to do the decrease, instead of adding 50ms, it adds a lot more then that. I don't have a display attached to it so I can't debug it but it's strange. Maybe a fresh set of eyes will be able to find the problem.
@ DEVICE PIC16F688, INTRC_OSC_NOCLKOUT, WDT_ON, PWRT_OFF, MCLR_OFF, BOD_ON,PROTECT_OFF
TRISA = %00111011
TRISC = %00111110
ANSEL = %00000000
CMCON0=7
PULSEOFFDEC VAR PORTC.4 'PULSE OFF DECREASE BUTTON
PULSEOFFINC VAR PORTC.3 'PULSE OFF INCREASE BUTTON
RELAY VAR PORTA.2 'RELAY OUTPUT
PULSEONINC VAR PORTC.1 'PULSE ON INCREASE BUTTON
PULSEONDEC VAR PORTC.2 'PULSE ON DECREASE BUTTON
ONOFFBUT VAR PORTC.5 'ONOFFBUTTON
ONTIME VAR WORD
OFFTIME VAR WORD
RELAY=0
ONTIME=500
OFFTIME=500
'------------------------------START OF PROGRAM---------------------------------
PAUSE 1000
START1:
IF ONOFFBUT=1 THEN
GOTO START1
RELAY=0
PAUSE 500
START:
'-------------------------PULSEONINCREASE---------------------------------------
IF PULSEONINC=1 THEN
ONTIME=(ONTIME+50)
PULSEONINCPAUSE:
GOTO PULSEONINCPAUSE
'-------------------------PULSEONDECREASE---------------------------------------
IF PULSEONDEC=1 THEN
ONTIME=(ONTIME-50)
PULSEONDECPAUSE:
GOTO PULSEONDECPAUSE
'-------------------------PULSEOFFINCREASE---------------------------------------
IF PULSEOFFINC=1 THEN
OFFTIME=(OFFTIME+50)
PULSEOFFINCPAUSE:
GOTO PULSEOFFINCPAUSE
'-------------------------PULSEOFFDECREASE---------------------------------------
IF PULSEOFFDEC=1 THEN
OFFTIME=(OFFTIME-50)
PULSEOFFDECPAUSE:
GOTO PULSEOFFDECPAUSE
'-------------------------ON/OFF BUTTON-----------------------------------------
IF ONOFFBUT=1 THEN GOTO MAIN_SEQUENCE
GOTO START
'------------------------- MAIN SEQUENCE----------------------------------------
MAIN_SEQUENCE:
RELAY=1
PAUSE ONTIME
RELAY=0
PAUSE OFFTIME
IF ONOFFBUT=1 THEN GOTO START1
GOTO MAIN_SEQUENCE
