is there a way to see the actual code from the chip so that i can change it. When I read the chip I am only able to see the HEX code. How do I see the actual coding??
thanks
thanks
The HEX is the actual code as far as the PIC is concerned.
You can load your HEX into MPLAB and turn it back into a more human readable Assembler. You can then make changes and reAssemble as you wish.
Thankfully there is no reverse compiler back into PICBasic.
MPLAB ? sorry, im a noobie
ok, i got the MPLAB. I imported my HEX, but i can't find any command to view the HEX in an understandbale language. How do i get it to work?
hi,
In the menu bar select View. Then select Program Memory. you should see those cute assembly lines...yukkk!!!!
