Hi Everyone,
This is my first use of a 12F675, and I used some of Bruces code, to BCD control the time period from a lookup table and it works really well. I am using his code to control LED off time, But I am trying to control on time using IF / THEN loops and the code simply ignores the IF / THEN loop as if it simply said 250. If I substitute a number in the B0 variables place it uses that number. Anyone have an idea why the IF/Then loop has no effect? I have moved it around within the code to no avail.
Thank You
JS
Code:@ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
PCON = %00000011 ' BOD off, No POR flag set
DEFINE NO_CLRWDT 1
OSCCAL = %1111100 '
CMCON = 7 ' disable analog comparators
ANSEL = 0 ' disable A/D module, all digital
WPU.4 = 0 ' disable weak pull up on GPIO.4
B0 VAR BYTE
X VAR WORD
Index VAR BYTE
LED VAR GPIO.5
TRISIO = %00011111 ' RA0 to RA3 inputs for DIP switch
OPTION_REG = %11111111
IF (GPIO.4 = 1) THEN
B0 = 2500
B0 = 250
Index = GPIO & $0F ' Read DIP switch AND mask result
LOOKUP2 Index,[200,300,400,500,600,700,800,900,1000,2000,_
3000,4000,5000,6000,7000,8000],X
HIGH LED
PAUSE b0
LOW LED
PAUSE X
GOTO Main
POKECODE @$3FF, $50 ' reintroduces osscal correction data
