My current code for testing purposes.
Thanks for the response.
I wrote this little test after I realized I used those pins. When this is running led's 0 through 5 will turn on for .5 seconds then go off. but 6 and 7 stay off.
Define ONINT_USED 1
i var byte ' Define loop variable
TRISC = %00000000 ' Set PORTD to all output
FOR I = 0 TO 7
PORTC.0[I]=1
NEXT I
LOOP: Pause 1000
For i = 0 to 7 ' Go through For..Next loop 7 times
PORTC.0[I] = 0
Pause 500
PORTC.0[I] = 1 ' Delay for .5 seconds
Next i
Goto loop ' Go back to loop and blink LED forever
So it's just not me then?
skimask
If I find a mistake, all I gotta do is cut a trace, and install jumpers across whatever via's fix the problems.
Sometimes I've got what looks like thousands of via's, but it works.
I'm glad it's not just me. I don't have allot of experience and I probably don't work on allot of projects but the ones I do no matter how careful I am I end up overlooking something. For this project I completely overlooked the fact the the ttl logic was not going to be enough to drive my 9v siren. Jeeze I know I'm no electrical engineer but what was I thinking!
Thanks again
David
my 2 little pins seems a pitance
I don't feel so bad either. I guess I only have 2 pins to re-route I should keep my mouth shut hehe.
I think this board actually turned out quite nice considering it's a complte do-it-yourself'er
http://www.jonzilla.com/thebittners/...ures/2007\Pool Alarm Project/
Oops try this link... I hope this works
