16F877 upgrade to 18F4620
I am finally jumping up to the 18F big boy toys....
I just ordered my first 18F4620 to replace a 16f877A I am using in an LCD board with lots of I/O's, 4x20 LCD, TX/RX and such. I have never used this chipset before. Can anyone tell me what to expect for possible programing problems, compatibility issues, and also how to use the internal oscillator of can I use my XT???
I am looking forward to the 4X Kword upgrade which is why I chose this chipset.
I would really appreciate any help.
Are we reading the same datasheet?
I downloaded the pdf file from microchip's webpage and read it.
It said:
Two External Clock modes, up to 40 MHz
These 2 modes are:
9. EC External Clock with FOSC/4 Output
10. ECIO External Clock with I/O on RA6
So it is not possible to use the PLL in these modes but the PIC will run at 40 Mhz if it has a 40 Mhz oscillator connected. I run several 4620 on 40 Mhz, both as 10 Mhz +4*PLL and as pure 40 Mhz circuits.
Also can this be found under absolute maximium ratings:
All devices 15 35 mA -40°C
VDD = 4.2V
FOSC = 40 MHZ
(PRI_RUN,
EC oscillator) <--------- look here!!!
16 35 mA +25°C
16 35 mA +85°C
All devices 21 40 mA -40°C
21 40 mA +25°C VDD = 5.0V
21 40 mA +85°C
So there should be no problem at att to run a 18F4620 with EC or ECIO configuration bits from an external 40 MHz oscillator if Vdd > 4.2V and if it is an industrial rated PIC (figure 26-1) the LF and extended rated PIC has a different behaviour.
/me
