Hello Everyone. I have a PCB with a 12F629 plugged into an 8-pin IC socket on it. All GPIO's are tied to VSS (ground) through a 47K resistor network. At this point there are no other connections to the ports and all 8 pins are readily accessable with an 8-pin connector. Is there an easy way to program the chip with my HEX file without having to remove it from the socket, put it into the programmer & then replacing it into the socket? Thank you.
