Saw a 5x5 display on you tube, daughter liked it so decided to make one.
there was no code for it, so here it is in PBP.
will have to extend the character set and add serial to change the message. but this was just for a quick toy, so I didn't do any of that.Code:'***************************************************
'* Christmas stocking stuffer for Andi from dad
'* 5x5 home made led display
'* pic 16F648A
'* December 2007
'* by: Nomad (DSobelman(at)hotmail(dot)com)
' USE ALL CAPS for now, will add lower case or lower case conversion to caps later
' very limited character set for now (no time to add the rest right now)
' added space at beginning of data, project was skipping first character
data " ANDREA ROCKS # MERRY CHRISTMAS MUNCHKIN #"
@ DEVICE pic16F648A, INTRC_OSC_NOCLKOUT
'@ DEVICE pic16F648A, HS_OSC
' osc setting
@ DEVICE pic16F648A, WDT_OFF
' Watchdog Timer
@ DEVICE pic16F648A, PWRT_ON
' Power-On Timer
@ DEVICE pic16F648A, MCLR_OFF
' Master Clear Options (Internal)
@ DEVICE pic16F648A, BOD_OFF
' Brown-Out Detect
@ DEVICE pic16F648A, LVP_OFF
' Low-Voltage Programming
@ DEVICE pic16F648A, CPD_OFF
' code protect
@ DEVICE pic16F648A, PROTECT_OFF
'data protect
defines:
'define osc 20
PORTB = 0 'turn off all
PORTA = 0
TRISB = 0 'all output
TRISA = 0
CMCON = 7 'disable comparators
Variables:
row var byte
col var byte[8] 'was originally going to do scrolling on 8x8 but didn't have a board
x var word 'how many random patterns in random sub
temp var word 'temp var for random HAS TO BE WORD (random doesn't work with byte)
rowx var byte[5] 'store constant for each row
char var byte ' index for lookup
lettermark var BYTE 'pointer to eeprom address
letter var byte 'temp for ascii convert
clear
constants: 'rows numbered 1-5, single each row out
rowx[1] = 1
rowx[2] = 2
rowx[3] = 4
rowx[4] = 8
rowx[5] = 16
start:
GOSUB READ_STRING 'READ EEPROM DATA
gosub get_char 'GET CHARACTER DATA
gosub display_run 'DISPLAY CHARACTER
gosub rand_disp 'SHOW RANDOM BLINKY STUFF (THEY LIKE BLINKY STUFF)
goto start 'DO IT AGAIN WITH NEXT LETTER OVER AND OVER
rand_disp: 'generate random noise on display
for x=1 to 5 'dispplay "x" random patterns (full 5x5(8x8) patterns)
random temp 'make random number
pauseus 50
PORTA = temp 'put out on porta (only uses low byte?)
random temp 'make row random number
pauseus 50
PORTB = temp 'put out on portb
pause 20 'how long to show pattern
next x 'next pattern
display_run: 'show characters
PORTA=0 'turn off all leds
PORTB=0
PAUSE 50 'forgot why this is here
for temp = 1 to 1000 'how many full character loops (how long to display character)
for row = 1 to 5 '5 loops, one for each row
porta = 0 'turn rows off (kill ghosting)
portb = col[row] 'put out row data for row(x)
PAUSEUS 100 'settle
porta = rowx[row] 'turn on row
pauseus 100 'settle
next row 'do again for each row to show full character
next temp 'show character again (refresh/scan/whatever you wish to call it)
read_string: 'read data (message) from eprom
lettermark = lettermark + 1 'go to next eeprom address
IF LETTERMARK > 255 THEN ' if at end hmmm don't think I need this anymore
LETTERMARK = 0 'was testing
READ LETTERMARK, LETTER 'read byte from eprom, assign to letter
IF LETTER = $FF THEN 'check for end of message
LETTERMARK = 0 'if end, reset eeprom pointer, make a space character
LETTER = $20
PAUSEUS 500
find_index: ' use lookdown to change ascii to a sequential index to keep lookup small
LOOKDOWN LETTER,["- #ABCDEFGHIJKLMNOPQRSTUVWXYZ"],CHAR
get_char: ' get each of the row's data with index from converted ascii
LOOKUP char,[$00,$00,$0A,$0E,$1E,$0E,$1C,$1F,$1E,$1E,$11,$0E,$07,$09,$08,$11,$11,$0E,$0E,$0E,$1E,$0E,$1F,$00,$11,$11,$11,$11,$1F],col[1]
LOOKUP char,[$00,$00,$1B,$11,$09,$10,$0A,$10,$10,$10,$11,$04,$02,$0A,$08,$1B,$19,$11,$09,$11,$09,$10,$04,$0A,$11,$11,$0A,$11,$02],col[2]
LOOKUP char,[$1F,$00,$04,$1F,$0E,$10,$0A,$1E,$1C,$16,$1F,$04,$02,$0C,$08,$15,$15,$11,$0E,$15,$0E,$0E,$04,$0A,$0A,$15,$04,$1F,$04],col[3]
LOOKUP char,[$00,$00,$1B,$11,$09,$10,$0A,$10,$10,$12,$11,$04,$0A,$0A,$08,$11,$13,$11,$08,$12,$0A,$01,$04,$0A,$04,$1B,$0A,$04,$08],col[4]
LOOKUP char,[$00,$00,$0A,$11,$1E,$0E,$1C,$1F,$10,$1E,$11,$0E,$0E,$09,$0E,$11,$11,$0E,$08,$0D,$09,$0E,$04,$0E,$00,$11,$11,$04,$1F],col[5]
