Hi guys,
i've made a simple circuit to measure the ad value from 2 channel of my 16F88 pic out to a LCD.
The strange thing is that porta.1 's values are conditioned by the results in porta.0 !
For example... this is what i get on my LCD...
Porta.1 = 5.00v lcd = 5.0
porta.0 = 5.00v lcd = 5.0
Porta.1 = 0.17v lcd = 0.17
Porta.0 = 5.00v lcd = 4.17
porta.1 = 2.54v lcd = 2.54
porta.0 = 5.00v lcd = 4.54
porta.1 = 5.00v lcd = 5.00
porta.0 = 4.58v lcd = 5.00
Here's the code:
output portb.7
low portb.7
Define osc 4
' Define LCD pins
Define LCD_DREG PORTB
Define LCD_DBIT 0
Define LCD_RSREG PORTB
Define LCD_RSBIT 4
Define LCD_EREG PORTB
Define LCD_EBIT 5
Define LCD_BITS 4
'variables
va1 var word
va2 var word
temp var word
volt var word
pause 200 'init LCD
lcdout $fe,1 'clear LCD
'Define ADCIN parameters
Define ADC_BITS 10 ' Set number of bits in result ( 8 or 10 bits )
input porta.0
input porta.1
ADCON1 = %10000011 ' set porta analog and right justify result
loop:
ADCIN 0, va1
ADCIN 1, va2
temp = (va1 */ 500 ) >> 2
volt = (va2 */500) >>2
high portb.7
lcdout $fe,2,"VOLTAGE..",dec (volt/100),",",dec2 volt,"V"
lcdout $fe,$c0,"TEMP.....",dec (temp/100),",",dec2 volt,"V"
pause 250
Goto loop
